SkidPro Tree Puller
/ SkidPro Tree Puller #21
Mine will work on the loader -- or 3-point hitch. I never use it on the back because it is so effective in front. The rear lift capacity is greater however there is no curl function there which is extremely important. I am not limited so much by the loader lift capacity because it will lift the rear tires off the ground on larger trees.
http://youtu.be/E_BO9AEoq8U
/ SkidPro Tree Puller #22
If you had a hydraulic top link wouldn't you have curl? My 3ph lifts more than double what the loader lifts. If you are lifting the back tires off the ground you are being limited. If you are lifting the back tires off the ground then you are not even meeting the rated lift capacity.
/ SkidPro Tree Puller #23
Dude, I like that! Who makes it?
But I agree, you maybe need more balast.
/ SkidPro Tree Puller #24
I looked at that design, and the one that's built like yours but the clamping action instead of going left and right it is going " to and fro " ugh "front to rear" ugh ? "away from the tractor then back". Of course you'd loose a little lifting power but could reach out farther or maybe in between something you didn't want to disturb. I use mine for keeping up the property not making a living with it so I went a little cheaper but I'm happy with it.
You may need to throw a little weight on the 3 pt hitch. Would make a smoother ride when the tree turns loose. I use a skid steer with it and man sometimes its worst than riding a bull.
/ SkidPro Tree Puller #25
These folks made it for me...
Buckthorn Puller - Custom built Skid Steer attachments to fit almost any need you may have.
Don't ask me to pronounce it!
I can easily add more ballast, but I am more concerned with bending my loader than flipping the tractor. Most of the trees I am pulling-out are willows. They come out easy and they are straight enough to put through the chipper whole, after sawing off the root balls.
/ SkidPro Tree Puller #26
At the extreme risk of hijacking back the thread I started, here is an update on the Skid-Pro tree puller I recently bought. It has been a very wet winter so, using either of our tractors, off road, has been and still is iffy at best.
As previously stated, my purpose for the tree puller is to find an easy way to remove yaupons around the bases of oak trees on our ranch.
First thoughts are that this tree puller will work well with bigger yaupons but, seems to just cut the smaller stuff, 1" and smaller, wherever you clamp on it.
Hard to see from tractor seat so, might have to install a camera on top of the tractor brush guard. Hard to determine when I'm at right place to close jaws when really close to a tree.
More later when it dries up a bit. Right now I'm leaving big ruts with tractor that will have to be fixed later.
Sorry to interrupt!
Sent from my iPad using TractorByNet
/ SkidPro Tree Puller #28
We were just keeping the thread active, waiting for your update. :)
More pictures please. :thumbsup:
Pulled the stump of a 6" tree, between several other larger trees that my 84" grapple couldn't get to. EZ-PZ.
We were just keeping the thread active, waiting for your update. :) More pictures please. :thumbsup:
Yep, that's what I thought too?
/ SkidPro Tree Puller #31
I find the trees pull out much easier when the ground is saturated. I am able to lift bigger trees when it is wet -- assuming I can get to them.
/ SkidPro Tree Puller #32
Yep. Springtime is best right after frost goes out. Ground is heaved from frost and roots don't have a tight grip.
/ SkidPro Tree Puller #33
Sorry to interrupt!
:laughing: :laughing:
When pulling small shrubs I just dig into the ground a little while clamping and grasping a part of the roots. Sometimes it helps from it just breaking off. I guess it sorta holds onto the dirt ball instead of the stem.
That's a nice fit for your LS.
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
Mermaid Statue (A64557)
Mermaid Statue...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
