robstaples
Gold Member
Chaostamer ,
I have 2 hydro blowers, but no expert. Looking at your pictures, what does the pump output go into directly? ( the part with a knob) Then by your sketch, the feed has a pressure gauge and then off to the front. I plumbed my pressure limiter to dump into the return to tank. I presume that is a return line filter. I use a suck line. Sketch your circuit. I had your symptoms when I had low flow. Also curious is the listing of your blower that is rated to work at 11-25 gpm. That's say 100 % speed to 227% speed. or 44% to 100% speed. Find your motor model or cu in displacement, then to find the max hp.
My experience ( limited and southern Michigan snow) is it's all about maintaining rpm. But heavy wet snow takes way more hp then fluffy.
