   / Your last generator Maintenance Run
While many people (myself included) have an interest in transfer switches and their use with generators, if this thread starts to degenerate the way others have, I will:
1) ask the offenders to to Take it Outside/Offline, or over into a thread of their own construction.
2) involve Mods if #1 doesn't work.
Recognizing that as the OP, I may be somewhat biased...... a lot of good information has been exchanged in this thread, in a constructive manner, which I'd like to see continue.
While I do find this thread helpful personally for equipment scheduling, I don't have a problem asking for this thread to be Locked if we devolve into trolling/flamewar nonsense..... I'd sooner have it stand as-is than watch that.
Now, hopefully, Back To Our Regularly Scheduled Programming ..... :)
Rgds, D.
   / Your last generator Maintenance Run #662
We were expecting freezing rain which usually means outages. Ran the generator for an hour, and as a friend was using the clothes dryer, this made an excellent load. The power never as much as flickered. I think the utility is getting back to their forestry work.
While someone on here managed to precipitate a grid-outage (;)) by changing the oil on their generator, most of the time...... If your generator runs fine, battery is charged, and you have plenty of stabilized fuel on-hand, the grid never goes down.
That's the flip-side of 'ol Murphy's Law that I like to be on.....
Given most of Canada's non-urban terrain, line maintenance is a huge ongoing task/cost.... it just takes one tree to take down a local line.
Rgds, D.
   / Your last generator Maintenance Run #664
I guess my main point, although I failed to explain it specifically, and as it relates to the thread, is the importance (so I have been told) of testing a genset under load. Apart from the possible wet stacking issues, if you have a diesel, testing the engine is only half of the machine. The rotor and stator should be put under load to keep moisture at bay. I guess certain parts of the country, need not concern themselves with this (like Arizona) , but most should keep this in mind.
   / Your last generator Maintenance Run #665
Once a year I throw the main breaker for each Hospital Wing and do a real honest test.
Tests all emergency and back up systems and gives the gen set a real workout.
We are limited to a total of 20 hours testing and maintenance annually and it is strictly controlled and verified.
I generally do it New Years... 150kW prime stand-by rated Onan with Turbo Cummins...
   / Your last generator Maintenance Run #666
I hope no one has brain surgery scheduled in the new year.
A commercial pilot friend once told me something interesting. Not sure if it's true, but Toronto Airport (Pearson) has their own generating plant, and uses the Utility as the back-up.
Agreed.
As an extreme example, if a utility-sized generator room floods, drying out the generators is a really big deal, requiring careful testing before power up. I've messed with enough systems, including high voltage, to know that you don't need flood conditions to have a moisture issue.
Rgds, D.
Job well done.... given that you are operating with one hand tied behind your back.....
Rgds, D.
IDK, but I could see that being the case...... if you are going to build a co-gen or tri-gen plant for something of that scale, it's likely cheaper to generate your own power than to pay grid rates - at least here, Natgas is plentiful, reliable, and reasonable cost.
Whole-house UPS systems have come up recently...... with a Natgas generator for recharging, you could duplicate what Pearson may have done, or just skip the grid altogether.....
Rgds, D.
   / Your last generator Maintenance Run #670
Rgds, D.
Your thread is about "generator maintenance", of which I do, with a backup power source with a 100% perfect track running record. Transfer switches are Covered on many other threads.
If you look at my past years posts, you will see I have some tips for maintenance irregardless of, if you run a transfer switch, or not.
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A55745)
2017 FORD F250...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
(APPROX. 20) 4' X...
1991 International 4900 Box Truck (A55302)
1991 International...
