Delete for dpf
/ Delete for dpf #1
Rc4510
Linden Alberta Canada
Ls xr4046 with cab
Mornin guys,does anyone know if a delete kit for egr and regen is made yet for a xr4046 siburha engine,no problem with mine yet but would be nice to get rid of PDF ect..thanks
/ Delete for dpf #2
It would be nice, someone will have to develop some simulators or a way to flash the ECM.
/ Delete for dpf #3
A zener diode modifying the reference voltage sending back to the ECU in place of the pressure differential sending unit and a test tube straight through the DPF would likely do it without need to flash the ECU.
iDrive TDS-2010H...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
