Buying Advice Next tractor advice
/ Next tractor advice #21
I can't imagine the Kioti being easier to unhook. Unless they have a system that doesn't require getting off the tractor it is going to be hard to improve on the Kubota method.
Oh yes the great Kubota. Face it the Kioti is better built. Imagine that...:laughing::D
No need to reattach my 3 point either.
/ Next tractor advice #22
Make nice boys. We're just talking shades of orange here. Save your bile for those nasty green things.
/ Next tractor advice #23
I'm kidding Ed:). His tractor weighs 8000 lbs so I'm sure its gonna be a bit harder to put it on that pig.:cool:
/ Next tractor advice #24
Yea, they just stuck the backhoe out another foot so it is more likely to get in the way. Who's backhoe takes up less room in the garage when we take it off? Why don't you go add up the total weight of my tractor.
See Ed, This guy is on his Great Kubota trip. I do not have a garage for my tractor. I have a Barn with a seament floor. My tractor weighs more than yours and will out lift it too.
/ Next tractor advice #25
I would hope so since it is a bigger tractor. It must make you feel good to outperform a smaller Kubota.
It makes me feel greeeeaat!:eek: Imagine that.:) Take care.
/ Next tractor advice #27
Relax, Murp......just because you are Irish, doen't mean you have scrap with ....the Orange.:laughing:
/ Next tractor advice #28
I'm green Irish. Does that mean I must buy a JD now?:D I'm not the one with the Orange complex.:thumbdown:
And to the OP I am truly sorry for the junk talk on your thread.
/ Next tractor advice #29
Your tractor with the loader attached weighs about 300 pounds more. Your loader is rated to lift about 900 pounds more. My tractor with loaded tires, backhoe subframe attached and box blade attached can still lift the back wheels off the ground. How does your tractor perform with maximum capacity on the FEL. I'm not trying to stir the pot, just asking a serious question.
That's roughly the same weight on the rear as my flail and I can lift rears too. Not sure what that proves though.
/ Next tractor advice #30
Oh well
/ Next tractor advice #31
I'm asking if it can actually lift 2,600 pounds. It doesn't matter how much the loader lifts if you can't keep the rear end on the ground.
1) the 2760lb rating is at pivot pins to full height. Not a real world number.
2) with the backhoe mounted, I was able to lift a granite boulder that by dimension measurement must have weighed between 2000-2400lbs. I could lift it three feet in front of pivot pins in a grapple to a height of about three feet. I wasn't dumb enough to lift it higher. I then moved it 50 feet and the rear end felt light but I had traction.
3) I haven't seen anyone else on TBN lift a bigger rock. I'll post photo later.
/ Next tractor advice #32
Ohhh, #3 sounds like a challenge! I bumped my pressure relief valve and put on the forks for some that should push you pretty good. (ps I don't actually care who's lifts more I just care that mine lifts alot and I'm happy your does too!)
/ Next tractor advice #33
This got out of hand quickly. I deleted all of my off topic post. You guys please do the same. I apologize to the op for severely hijacking his thread.
/ Next tractor advice #34
This is TBN. We get off topic all the time. Lots of interesting stuff comes out of off topic discussions so I for one don't like post hoc editing/deleting posts. The getting snippy part is no loss but practical discussion of (and even seeking bragging rights) loader capabilities is perfectly in line with giving tractor advice IMO.
In that positive vein, here is a photo of the rock I pulled out of the ground. It was sticking out about four inches or so I I kept hitting it with my flail so I decided to grab it. I had no idea how big it would turn out to be. The grapple hooked on just with one tine on top and that tine got splayed out if that is any indication of how heavy the rock was. The grapple held though and I literally just lifted the rock out of the ground (sandy soil). At the time someone asked me to measure it to calculate the weight. I forget the actual measurements but I recall the length was about 42" in the longest dimension. Again, just going from memory, based on the density of granite, it weight something north of 2000lbs and south of 2500lbs. I don't think I could have lifted it without the BH as ballast. Even then the rear felt very light as I moved it.
The stump in the other set of photos is an oak and is about the heaviest stump I ever lifted. I couldn't lift it out of the hole with the loader but could with the BH. I then was able to lift it with the loader and carry it about 150 feet. Max'd out pretty much.
So, these are the practical real world limits of loader on my DK40se/BH. Not trying to out do anyone just showing what a 40hp tractor with 2760lb lift rating (pivot pins to full height) can do.
/ Next tractor advice #35
That's a big stump.
/ Next tractor advice #37
Oak too. I had to shake dirt out of it in order to lift it.
Ok, it never looks as big in pictures (that's what she said) but this one was about all she could handle!
Ones like this are no problem.
Sent from my XT1080 using Tapatalk
/ Next tractor advice #39
Those were mostly burried but I have them everywhere! Everywhere.
/ Next tractor advice #40
The rocks in the background came just from clearing the surface to be mowable in the area you can see.
That wall is almost 5ft high and about 3ft thick
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2006 Hudson Brothers Trailer HTD18D Trailer (A62613)
2006 Hudson...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
40ft Shipping Container (A64194)
40ft Shipping...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
