Quad tires for PT Tires
/ Quad tires for PT Tires #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Trying to think of why this would not work, outside of a clearance issue, but wondering if I could use a quad tire on the ol PT. Next year will be tire replacement year.... and as I have 11 tires to replace, gonna need some serious cash to pull this off. Found some quad tires I liked the tread pattern on and was just thinking it through.
/ Quad tires for PT Tires #2
Just make sure the load rating will work. I can't find any specs, but I am guessing the PT weighs significantly more than a quad.
/ Quad tires for PT Tires #4
I know next to nothing about Power Tracs. They look like a great machine. How is it you need 11 tires? I thought they had 8.
3 spares. When you are working in the woods, and on steep slopes sideways, you get rolloff a lot. stump will catch the tire with low PSI and mess your day up quick.
Load rating and bead strength, now where would a guy find that info?
/ Quad tires for PT Tires #6
What tires do you have now?
I don't know where you'd find bead strength, but load rating I would think is the maximum load.
Try this link to the Carlisle site (I have these on my little 425) and you'll see some specs for tires.
I'd look for ply (more plys. In your case, WAY more pls! :laughing: ) and load rating.
/ Quad tires for PT Tires #8
IMO, tires for ATVs/SxS simply will not work on a PT. They are mostly 2 ply, most with a load rating of 450-600 lbs. To find tires that will hold up to the heavier SxS requires careful research and selection - and even then, quality suitable tires will end up costing about $125 each ($100-150).
The PT application is FAR more demanding, because of the load that can be placed on the front tires, especially doing loader work. Remember that a "PT pucker" situation puts the ENTIRE weight of tractor, attachment and load on the front tires. Combine that with the low pressures used, and it requires a very strong sidewall to handle it.
Given where and how you use your PT, I'd recommend you use tires of 6 ply rating, even though you run duals all around. My two cents!
Ply on these ATV tires are 6 ply.... seems standard with the more agressive lugs
That said, load rating is barely 500lbs
Kenda Executioner
Looking at what Carlisles have seems like that is what kills the quads is the load rating.
/ Quad tires for PT Tires #11
Should have bought those tires and rims JJ told us about. I am really glad I did. $50 for tires and rims - hard to beat. I liked them so much I bought more as spares.
Ken
Yup... bummer... Well, you are the king of deals, I am sure you will find them again and let me know.....
This week I had to replace my quad tires (they were due) and my truck tires - they were not due. I need to figure out what kind of tires I want on the PT. I have both Carlisle balloons (factory) and then I have skid steer. Never sure of the side holding on the skid steer.
Anyone have thoughts on that?
/ Quad tires for PT Tires #13
What do you mean by "Never sure of the side holding on the skid steer"?
/ Quad tires for PT Tires #14
I think he means that he's not sure of the sidehill traction of the R-4 skidsteers tire, compared to R-1 ag lugs. IMO, Unless you plan to use chains or use the PT on your lawn, the R-1 at lugs are clearly the way to go. But, the Carlisle Super Lug is one of the poorest lug tires out there, IMO, because it has fewer lugs and wider spaces between the lugs.
Yeah, sorry, referring to slope tractions. Getting up at 45 degrees, The Carliisle are all soft and bouncy, the Skids Steer tires are like rocks. Wondering how traction is effected, or should I say stiction?
/ Quad tires for PT Tires #16
I have the Carlisle R-4s. Chains definitely improve the traction when I'm brush cutting behind a 72" brush cutter. Whenever it is wet, or I'm cutting something slimy, I always use chains.
I think it comes down to your soil, and what you are trying to do. My clay soil goes from mush to gravelly dust in a couple of weeks. When it is mush, I don't even try to take the tractor out on a 25 degree slope. Mostly I spin out going straight up hill on the dry stuff, though I side slip a little. On wet, slimy cut thistle, the side slip is noticeable, but with chains, much, much lower. Ag bar tires would be worse- for me.
All the best,
Peter
/ Quad tires for PT Tires #17
[Trying to think of why this would not work, outside of a clearance issue, but wondering if I could use a quad tire on the ol PT. Next year will be tire replacement year.... and as I have 11 tires to replace, gonna need some serious cash to pull this off. Found some quad tires I liked the tread pattern on and was just thinking it through.]
I have an older PT-422 with the same body style as the newer PT-425.
I just put on a set of Kenda K502 4-ply off-road tires in size 23-10.5-12 designed for the small truck-like quads. They have a load rating in excess of 1340 pounds...very typical for a 4-ply tire which was standard on my machine. (Like the Carlisle turf tires and many of the tractor lug tires.)
I wanted the traction of the lugged tire, but need the turf-friendly behavior of the flatter treads. I think this is a great solution somewhere in the middle.
My property is a mix of woods, turf, and mud and is sloped at up to 25 degrees (much steeper than 25%) in places. These tires provide traction sufficient to climb the muddy hills in the steepest areas . I was amazed when I took it out the first time. It was raining and had made the hills too slick to walk on. The machine drove down, stopped and then backed up the hill with ease. Further, the tearing on the soil was minimal. I was impressed after slidding down these same hills in the dry on the turf tires.
As for load; the rating for the tires allows my weight, the full weight of the machine, and the full 800+ pounds of lift (ready to tip forward) to be safely carried by the front tires alone with 500 pounds to spare. Thus even on a side slope fully loaded, the downhill tire should safely stay in range. Further, these tires are designed for full load at up to 60 miles per hour, making the rating at slow speeds even a bit more conservative as it will not have the same heat generation.
If interested, they can be had on line for $144/pair with $25 delivery. My local shop mounted them for $25 for the 4. (Yes he is inexpensive) Thus, 4 new shoes for $375.
Rick
Still going strong after 2800 hours....but with new tires.
/ Quad tires for PT Tires #18
I think once you get up in the 45% range, stiction is probably the better word! :laughing:
/ Quad tires for PT Tires #19
Just to save others have having to google, here is what they look like:
Those look like a good compromise between lugged and turf tires.
Where did you buy them from? That sounds like a killer deal.
/ Quad tires for PT Tires #20
I wish that tire came in 24x12x12 for an F3680. The turf master tires on it now just are not that good. The closest I've found is the Carlisle HD Field Trax ATV Tire, but it's not a 4 ply tire.
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A59231)
2018 Freightliner...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 DORSEY 53X102 EXTENDABLE TO 90 FT (A59905)
2014 DORSEY 53X102...
