Keurig coffee maker warning.
/ Keurig coffee maker warning. #21
I still use an electric percolator that was given to me. Works great. The best percolator is the one that you can use on a fire.
No electrics to go out on it.
I like simple things.
I have both, I like my coffee hot and good old Maxwell House is fine with me. I fill the electric the night before so that it's ready to be plugged in.
The stove top is nice when the power goes out. Also, sometimes when I'm hunting I'll stop and build a fire in a gravel pit to cook lunch, a cup of fresh perked coffee with it goes down good.
After a while the electric stopped getting so hot. I bought a $10 thermostat online, now it's good for another 10 years.
/ Keurig coffee maker warning. #22
It's hard to believe that we've taken something as simple as boiling water, and made it complicated.. unreal
/ Keurig coffee maker warning. #23
I get your point - but it's not about boiling water. It's about convenience. The single cup brewers are quick, and you don't wind up pouring out a 1/2 pot of hours old coffee.
/ Keurig coffee maker warning. #24
My wife uses the coffeemaker and not me, I nuke water in a cup and stir in a spoon of instant...at my age my taste buds cannot tell the difference anyway.
/ Keurig coffee maker warning. #25
We use distilled water in our Keurig and haven't had to clean the water channel in months. Get the distilled water in 1 gallon jugs at Wally World for 84 cents each. I also use distilled water to top off lead acid batteries in vehicles and tractors.
Sent from my iPad using TractorByNet
/ Keurig coffee maker warning. #26
Our Keurig will be 3 years old next month. The manual says to descale every 3 to 6 months, or anytime the "descale" light comes on. The light has never come on, but I've run the vinegar through it TWICE in 3 years. It was 20 months old the first time I decided to descale it. It got heated up and the vinegar barely dripped a bit, and stopped. Then it would not pump vinegar or water, and I finally decided it was dead and would have to be replaced. So, with nothing to lose, I took it out in the shop where my air compressor has 150 psi and I blew compressed into and through every place I even thought the air might go. Then I took it back in the house, put the vinegar back in it, finished descaling, flushed it with a couple of tanks of water, and it worked just fine. So 4 months later I descaled it again with nothing unusual happening, and it's worked just fine ever since. Maybe I ought to try descaling again, since the last time was January 3 of this year.:laughing:
/ Keurig coffee maker warning. #27
I have to pay 88 cents a gallon at Wally World, and use the distilled water in my CPAP machine, but have never used it in the coffee maker.
/ Keurig coffee maker warning. #28
A cleaning alternative to vinegar is to use ascorbic acid. We learned this years ago from our local appliance repair man. He was up repairing the stove and we mentioned the spots on glassware from the dishwasher. He said to use ascorbic acid (vitamin C powder) rather than the commercial (and expensive) dishwasher additives. Adding a bit(teaspoon?) each time works great to prevent spots and keep the dishwasher free of scale.
Going to try this one. You can also get ascorbic acid in the canning section of the store. We have a big jug of the stuff.
Later,
Dan
/ Keurig coffee maker warning. #29
Later,
Dan
So...you just dump the powder into the rinse dispenser? What is the ratio? We have used Jet-Dri in our GE dishwasher since it was new (2003) and the cost is very low. Come on now. I want to learn REAL FACTS from members who have used this method of ascorbic acid...not just hearsay. And BTW. what rgustafson says about using distilled water to top off batteries...I have NOT HAD TO TOP OFF A BATTERY THE LAST 15 years...be it a car, truck, ATV, tractor, RV, battery, whatever....
/ Keurig coffee maker warning. #30
Guess you are just lucky then. Ever check your batteries?
/ Keurig coffee maker warning. #31
Later,
Dan
Huh?
I said I would try the ascorbic acid and see if it worked. I did not say I had tried it or it did work.
Given that a TBNer said he had used it and it worked, I would think that is a fact. The person who suggested to use ascorbic acid mentioned the amount to use.
Later,
Dan
/ Keurig coffee maker warning. #33
You still have batteries that are not sealed/maintenance free?
Geeze! I thought this thread was about coffee makers? I keep distilled water around JIC I need some for batteries. No, not all are sealed, guess it the distilled water keeping them going?
<OS_dispatch_semaphore: 0x18811f20>
/ Keurig coffee maker warning. #35
You have a touchy CPAP, Mine takes tap water no issue.
I suspect mine would, too, but the initial instructions were to use distilled water, so I've been doing that.
Bought four bottles of descaler at $4 each and wife had $5 off $15 coupon. Sometimes that coupon stuff amazes me. I will use it whenever the warning comes up on the machine. Don't want that problem again.
/ Keurig coffee maker warning. #37
Geeze! I thought this thread was about coffee makers? I keep distilled water around JIC I need some for batteries. No, not all are sealed, guess it the distilled water keeping them going? <OS_dispatch_semaphore: 0x18811f20>
I know even less about those fancy coffee makers than I do batteries. I remember adding water to batteries, I just didn't remember doing it in a long time. Just commenting, not trying to stir the (coffee?) pot.
/ Keurig coffee maker warning. #38
Yes, we use about a teaspoon in the rinse dispenser. It works far better than the commercial products. We were using a commercial "spot eliminator" that was not doing the job, thus the question to the repairman. I looked up the record when we bought this stuff (I use Quicken). We bought 30 pounds from Sure Crop Feeds in Grindrod for $85.50 including tax(probably around 12%) on December 1, 2005. We still have a couple of small pails of the stuff and gave samples to friends.
It is great for cleaning scale and sediment off copper plumbing fittings, garden sprinklers, etc. If you put them in a dish with a strong solution small bubbles start immediately and the fittings will be completely cleaned.
Here's a photo of a couple of tap fixtures I cleaned just for fun when I changed them last year. I don't have "before" photos but they were completely covered and gummed-up with green and white scale:
/ Keurig coffee maker warning. #39
kco, thanks for the clarification...I will give your method a try but am darned if I am going to buy 30 pounds...:laughing: but we do have a problem here with super hard water although it is run through a premium softener which helps somewhat.
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
We do NOT accept credit cards as payment. (A62177)
We do NOT accept...
2012 Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 Chaparral...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
17in. Tooth Excavator Bucket (A60352)
17in. Tooth...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
