Ho to get rid of mice in the chicken coop and run
/ Ho to get rid of mice in the chicken coop and run #1
kcflhrc
Kansas
2013 John Deere 3032E
How to get rid of mice in the chicken coop and run
I'm sick of these **** mice tearing up insulation and crapping everywhere. Any recommendations on how to eradicate the little buggers????
/ Ho to get rid of mice in the chicken coop and run #2
I have had success in the house from the annual autumn invasion of mice, using the following methods:
1.Sticky mouse cards called 'Trapper Max'...they walk on it, get stuck and then you drown them in a bucket. You would have to put a crate with openings over the cards otherwise the chickens would get stuck and its impossible to remove anything from them once stuck including socks (I know cos I tried after I stood on one). Dab of peanut butter in the centre of the card helps. Amazon.com: Trapper Max Mouse & Insect Glue Boards-72 Boards: Industrial & Scientific
2. The 'clever mouse trap'. Dab of peanut butter on the inside cap and they are straight in, trap tips up and door closes behind them. Works much better than ordinary mousetraps. Not sure where they are for sale in the US. MOUSE TRAP : THE CLEVER MOUSE TRAP
Thinking about it, these work on being set by balance, meaning if they are knocked even slightly they will tip and close....one tap from a passing chicken and that's it, so possibly not suitable for your situation.
3. The blue blocks of poison do work a few days after the mice eat them but the chickens might get at the blocks or the crumbs the mice leave trailing about plus if the chickens eat some it could get into you via the eggs so I would avoid poison...the above 2 methods work better and quicker anyway.
/ Ho to get rid of mice in the chicken coop and run #4
Seal all access to the coop.
If not possible, I don't see how you will stop the mice from entering the coop in the first place.
Later,
Dan
/ Ho to get rid of mice in the chicken coop and run #5
Set up a 5 gallon bucket trap (google it) in a corner, with fence around it to keep chickens away.
It's difficult to catch them with all the chicken feed readily available.
/ Ho to get rid of mice in the chicken coop and run #7
Glue traps mentioned above work great, however in cold weather the glue becomes less effective.
Instead of baiting the glue traps I use them at pinch points, such as at a crack in a wall they pass through. Since they have all the free food they could want (chickens are messy) I think you'll have better luck this way. Another thing I like to do is put a single deck screw through the glue trap to the floor. I have had a big mouse run off with a glue trap stuck to him and lodge himself elsewhere, die, and stink the place up.
I will say when we had chickens the rats and mice where just part of it. It was a never ending battle.
/ Ho to get rid of mice in the chicken coop and run #8
;) Put your chickens on steroids and train them to develop an appetite for fresh mouse.
… or rent out one of Streetcar's Cincinnati roosters for a few weeks.
They already have the appetite for mice. They just cant catch them all
/ Ho to get rid of mice in the chicken coop and run #10
That's how mine were. The smart mice survived by staying on/in the walls and in the feed room. Any mouse within pecking distance caused a riot with the chickens... first come, first served.
/ Ho to get rid of mice in the chicken coop and run #12
Is that because of fast mice ? :mouse: or slow chickens ? :chicken:
… you just need to find a way to slow the mice down ;)
maybe put little mouse speed bumps along the edge of the wall.
/ Ho to get rid of mice in the chicken coop and run #13
My 4 barn cats keep the mice population down and never bother the chickens. Now if I could just stop the rat snakes from getting my chickens.....
/ Ho to get rid of mice in the chicken coop and run #16
Simplest solution for getting rid of mice - peppermint oil! The little buggers can't stand the smell. Dab some peppermint oil on cotton balls and place them strategically around. In a coop, you can punch holes in a can and place the cotton balls in the cans. You'll also have the best smelling chicken coop in the county! You can get the oil in health food stores. It's not cheap, but a little goes a long way. We had mice in the house all the time. Now I use it in the crawl space under the house and in the attic. No more mice.
How about some good old-fashioned mouse traps? I like the modern black plastic snap traps that you can reset with one hand.
Not a real good idea with chickens around
Worth a shot,
Thanks
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2000 Sakai SV505 (A64119)
2000 Sakai SV505...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
UNUSED WOLVERINE QUICK COUPLER 10 (A64281)
UNUSED WOLVERINE...
