Magnet Mounted LED ROPS Lights - PICS
/ Magnet Mounted LED ROPS Lights - PICS #1
KYKub
East KY
Kubota - BX 1860 and G1900
Getting ready for snow and decided to follow the lead of others on this forum and install auxiliary lighting on my BX. Found the factory-installed auxiliary power wires under the seat.
Ordered 4 18-watt LED lamps from Amazon. After reviewing several other folks' installs, I decided to go with mounting lights to ROPS with magnets. No drilling into ROPS and the flexibility to remove or move to rear of ROPS when not needed. I ordered 2" diameter magnets, drilled center holes to accommodate mounting bracket bolt and attached each light to a magnet.
Ran wires through split loom conduit into a box mounted on the safety sign bracket. I never use the tractor on the road so didn't need the sign and the bracket made a perfect mounting place for a switch box.
The auxiliary connection is hot any time the key switch is "on" so a switch is needed, unless you want the lights always on. I first installed a couple of exposed small rocker switches, but decided I liked the box mount better. A nice clean install on the dash would be great, but I didn't want to learn from mistakes in trying the install in dash.
Opinions: 1) The magnets hold the lights very securely. I wouldn't try this method if I was operating in an environment where they would get caught on limbs all the time, but for winter plowing they are great. I originally planned to move or remove them for use other than plowing, but I'll leave them and see how it goes. It would take a pretty good whack to move them. I used 2" magnets but it would be even more secure with a 3" magnet (ROPS is 3"). Magnets also allow you to easily position for front, rear, or side lighting. 2) The lights are very bright with draw of only 1.5 amps per light (4 lights = 6 amps). It's hard to "show" light coverage at night with a photo, but two lights facing forward and two facing rearward offer plenty of nice white light for my needs. 3) The lights are better quality than I expected from an $11 product ($44 total for four). Aluminum housing and low profile.
Glad to have this forum as a place to learn and copy good ideas!
/ Magnet Mounted LED ROPS Lights - PICS #2
It snows in KY?!:confused2::eek: Who knew?!:laughing:
Nice job, pics, etc.
Part #s please, lights and for magnets too.
Thanks
CM
Thanks, CM. Yep, snows in KY! Nothing like VT, but just enough to need to plow a handful of times each season. A 6" snow is a pretty good snow around here.
Here are Amazon links:
Lights - Amazon.com: Signstek 2*18W CREE LED Flood Light Headlight Work Light Lamp off Road High Power ATV Jeep 4x4 Tractor off Road Light Fog Driving Bar Rree Truck SUV Car IP67 Waterproof Dustproof Shockproof (Black): Automotive
Magnets - Master Magnetics RB50CX6 Round Base Magnet Fastener with 0.197" Center Hole Chrome Plate, 2.04" Diameter, 0.302" Thick, 35 Pounds, Silver (Pack of 6): Amazon.com: Industrial & Scientific
/ Magnet Mounted LED ROPS Lights - PICS #4
Tried same idea with a small FEL mounted video camera. Unfortunately the vibrations and shocks from the loader arms kept knocking it out of alignment even when mounted using a 220lb pull magnet.
/ Magnet Mounted LED ROPS Lights - PICS #5
Looks like a clean install and easy to remove if you ever feel the need. If I might make one suggestion, it would be to run a small piece of wire or cable (like a guitar string size) to "catch" them if they were to hit something and get pulled off. That way the electric wire won't be whats catching them and possibly getting torn out. You can run it a half inch shorter than the electric wire and through the same loom to a secure spot. I've had temp mounted things come off in the weirdest ways and it usually costs me money.
/ Magnet Mounted LED ROPS Lights - PICS #6
Thanks! And may all your storms be few and light, but enough to have to get out the plow and kick the snow's butt!:thumbsup:
Thanks for the suggestion, JJ. You're right, and given that my plan is to leave them on and see what happens, it's a certainty that I will end up dragging them off at some point! Maybe a piece of wire connected to the zip ties would do it.
Funny, I used to dread shoveling snow, then got a Kubota G1900 with plow blade and enjoyed plowing. Now have a BX with FEL and Snow Rake and can't wait to play in the snow!
/ Magnet Mounted LED ROPS Lights - PICS #9
Looks good. Could you post some more pics of the switch box? I like the placement of it.
/ Magnet Mounted LED ROPS Lights - PICS #10
Nice work, and great idea with the magnets.
/ Magnet Mounted LED ROPS Lights - PICS #11
Oh, Fort Knox had snow.....But a friend of mine lives in Knoxville and I asked him what they use to clear the roads of snow. "The sun." :laughing:
This is clever and has me thinking. I have a bunch of small rare earth magnets. We embed them in 3D printed parts all the time. I'm going to see about making plastic brackets with embedded magnets. Rare earth magnets are 50-100% more, well, "magnetic."
/ Magnet Mounted LED ROPS Lights - PICS #12
Question, could you take a pic of the magnet on the under side? Is the hole counter sunk so the bolt sits flush? I love this idea and want to do the same on mine (even though it's green :)).
Thanks for the feedback, guys. I'm pretty happy with how the project turned out. Here are some additional pictures of the switch box. The "switch" is actually just a toggle lever that engages a regular light switch mounted in the box. I know it's an AC switch in a DC application, but at this low amperage it seems to work ok. Box/switch came from Rural King, but they're available at most home supply box stores.
Garandman, sounds like you have a more fully developed plan for using magnets. I'm happy with this application, but stronger magnets would make it even better. As requested, here are a couple more pics of the magnets I used. I drilled the hole larger to accommodate the mounting bolts. The magnet has a recessed hole so the bolt head doesn't interfere with the magnet. Again, if I did it over, I'd use 3" magnets (these are 2").
/ Magnet Mounted LED ROPS Lights - PICS #14
Thanks for the additional pics. This looks like the perfect plan, then it's easy to re-position the lights if you need it at a different angle for a different purpose. Great work!
/ Magnet Mounted LED ROPS Lights - PICS #15
Funny you just posted this up, I just finished up my magnetic mounted lights last week, I use Velcro straps to help hold the lights on and secure the extra wiring I gave them for moving the lights around on the rops.
TMGT, were you happy with the installation? I'm pleased with mine and wonder why I don't see more folks doing this.
/ Magnet Mounted LED ROPS Lights - PICS #17
I also now use magnets.
My rear floods, strobe and camera are all mounted with magnets.
No matter how I tried to seal the attachment and wire pass thru, my strobe always let water in so I plugged holes and went magnet.
Recently I modified a pals strobe to magnet simply because his shed door was too low.
A side advantage is that low branches no longer damage the strobe light, simply let it dangle at wire's end.
A magnet mounted flood or spot allow for maximum adjustments as well if you leave some extra wire to relocate. (I use shielded wire for extra ruggedness)
LOL, a good magnet is also a great tool retrieval system if you drop your favorite tool into the deep water.
My radio antenna is also magnet mounted so I no longer need to replace due to low branches.
Magnets to me are joining duct tape, vice grips and WD40 in the 'go to' KISS dept!
/ Magnet Mounted LED ROPS Lights - PICS #18
Thanks guys! I was thinking of replacing my halogen flood light on the tractor, I think I'll go ahead with a couple of these.
/ Magnet Mounted LED ROPS Lights - PICS #19
Same here. As to solid mounted ROPS, even on the underside, my brackets catch on limbs which has cracked the glass lens, has bent up the mounts and knocked the lights all which ways. I've repaired the lens and hardware and taped up other damages.
Thus a magnetic mount looks a lot better to me. Plus the cost of this halogen set up was a lot more to begin with.
/ Magnet Mounted LED ROPS Lights - PICS #20
I love mine although I haven't used the tractor much since I finished it (darn rain). I like the ability to position the lights where I need them easily, like when using the backhoe I can turn all 4 around for better side coverage.
I also used quick connectors for each light so I can steal them for other equipment or replace them easily if need be.
I'll try to get some pictures now that it's dried out.
