4 wheel steer problem
/ 4 wheel steer problem #1
ulmn
Member
ottawa
i have the 4 wheel steer switch in the 4 wheel steer position and only the front wheels turn (the rear arent aligned), and if i switch it to the 2 wheel steer when the light is on, and turn the wheel it blows the 20 amp fuse and kicks a 50-56 code
i tried disconnecting one solenoid at a time on the valve block in the back it still blows the fuse if i remove either of the top 2 solenoids
if i disconnect the botom solenoid it doesnt blow the fuse
what does each solenoid do?
does anyone have a service manual i can download?
/ 4 wheel steer problem #2
ulmn,
The 50-56 error code is referencing a communication error. There is a short in that circuit. Is this intermittent?
It only happens when. Flip the 4 wheel steer switch
I pulled the 3 coils off the valve block in the rear
The bottom coil is bad only reads around .4 ohms
The other 2 read around 6 ohms
Does anyone know if there is a parts microfiche for the toolcats online?
What about a PDF copy of the service manual?
/ 4 wheel steer problem #4
Using Windows IE go to Bobcat.com, then at the bottom of the page, click "Parts and Accessories" under "Ownership".
Click "Parts Catalog", then download and install "ArborText IsoView".
/ 4 wheel steer problem #5
i have an issue with my 05 B series toolcat the back wheels constantly go out of alignment without touching the switch at all any help would be appreciated
/ 4 wheel steer problem #6
From this and your other post its sounding like your AUX Hyds. are stuck on. :thumbsup:
/ 4 wheel steer problem #8
thanks ill check that
No need to check. Thats why I asked if the engine was laboring. How many hours on unit? Have drive motors ever been replaced? See "Weak drive on 5600s' thread. :thumbsup:
/ 4 wheel steer problem #9
When trying to turn while using 4-wheel steering on hard surfaces like asphalt and Im at a dead stop, I have to crank my engine up pretty good to get my D-Series tires to turn. If I don't the steering feels 'notchy' and it's like trying to turn the wheels on a very heavy vehicle without power steering. It's better in 2-wheel steer but it's not like power steering in a car at all. I don't remember the steering being this difficult when I first bought it (new) back in 2008 but it does seem to be getting worse and worse the last few years. I just really noticed it today when I was moving 1 ton pallets of rocks around. Can I assume this is normal? Is there something that going out on me?
Thanks, DEWFPO
/ 4 wheel steer problem #10
Thanks, DEWFPO
Sounds like its time for a pressure test and a steering relief test. :thumbsup:
/ 4 wheel steer problem #11
the drive motors have ever been changed on the machine, I just went and checked that there is 2800HRS on it
/ 4 wheel steer problem #12
Definitely see "weak drive on 5600s" thread and follow the directions. A failed or failing drive motor can produce the symptoms you are experiencing. Early toolcat drive motors had issues. :(
/ 4 wheel steer problem #14
Is this something I can do or do I need to have a tech come by?
Thanks, DEWFPO
Your probable better off getting a tech to look at it. They will have the correct diagnostic port couplers and gauge. :thumbsup:
ALUMINUM TRUCK TOOL BOX (A64278)
ALUMINUM TRUCK...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
UNUSED IRANCH IRTPL TWO-POST LIFT (A65055)
UNUSED IRANCH...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
UNUSED PARBREAK GCC56 2 PRONG BALE SPEAR (A65055)
UNUSED PARBREAK...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
