Fuel additive
/ Fuel additive #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
How much power service white arctic do I mix to 10 gallons of diesel fuel?
/ Fuel additive #2
Four ounces to 10 gallons above 0* F and eight ounces below 0* F.
/ Fuel additive
thanks!
/ Fuel additive #4
In case you want to use a different type of additive, or have a different amount of diesel, it's really easy to figure out.
The instructions say:
At temperatures above 0F., add entire contents (16 ounces) to 40 gallons of diesel fuel. When temperatures drop below 0F. or when using biodiesel blends, add entire contents (16 ounces) to 20 gallons of diesel fuel.
To figure the amount per gallon, divide the additive amount by the fuel amount.
In this case 16 / 40 = 0.4 which means 0.4 ounce of additive per gallon of fuel. 10 x 0.4 = 4 ounces.
Below 0F
16 / 20 = 0.8 which means 0.8 ounce additive per gallon of fuel. 10 x 0.8 = 8 ounces.
2008 New Holland T2420 (A62177)
2008 New Holland...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
Utility Cart (A59231)
Champion Vibratory Roller (A60462)
Champion Vibratory...
