Rear Blade Kubota B2650 Rear blade length
   / Kubota B2650 Rear blade length #1
fraserfir
High View WV
B2650 kubota
Will a Woods RB 600 or 6 Ft. Rear Blade work ok to remove snow on my B2650 Kubota tractor ?
   / Kubota B2650 Rear blade length #2
I say yes. For years I used a 6' rear blade on an old Ford 2N. I did a search on the Woods RB600. It appears to be offset capable and tilt capable. Those are good features to have. Have you seen pics of the blade that is for sale?
   / Kubota B2650 Rear blade length #3
For snow removal, optimally you would want rear chains or loaded tires or both but you could try it without first to see. Depends on how deep the snow and hills.
   / Kubota B2650 Rear blade length #4
6' would be perfect for that tractor.
Would it be to much if I was to grade my driveway. The tractor wheelbase is like 54 inches wide. Thanks for everyone's opinion.
   / Kubota B2650 Rear blade length #6
You want the blade to cover the rear tire tracks when it's angled, which is why it needs to be at least 1.15 times wider than the rear wheels. So take the rear wheel measurement to the outside of the tread, multiply by 1.15, and get the blade which is that size or closest without being smaller.
I have the 6' blade on an L3200, which measures 60" wide to the outside of the rear wheels. I believe the B2650 is close to same dimensions as the L3200 in length, but don't recall comparing width. Anyhow, it's big for a B, so I suspect the 6' blade is what you want.
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2025 LandHero Universal Bucket Pins (A49462)
2025 LandHero...
71052 (A49346)
71052 (A49346)
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
