TA-170
/ TA-170 #1
lonestar6
Parker. PA
Kioti DK45
The TA-170 all-inclusive package is priced at $7,060. This loader package is designed to work great with your tractor. The TA-170 package includes the loader, 60 Bucket, a custom set of Mounting Brackets, Hose Kit, valve & joystick, and the patented Power Mount system to install and remove your loader in less than 2 minutes without any tools or stands.
Whatyou see above in red is a $ quote I got from Westendorf....it's a bit pricey for me. I'm not sure what path to go down. Single, double skeleton bucket etc. My head was hurting from over analyzing.....I'm a weekend warrior to do clearing, not an everyday user. Any recommedations would be appreciated!!! Thank you for the reply. :thumbsup:
/ TA-170 #2
Hi. :wave:
I hope you don't mind, but I moved your post around a bit. I thought you might get more answers over in the buying, pricing and comparisons section.
/ TA-170
Hi. :wave:
:confused3:Thank you Catherine....I don't mind at all. This is my first time at using a forum of ANY kind & I'm prone to making "rookie mistakes". Have a wonderful Thanksgiving.....:ashamed:
/ TA-170 #4
Have you priced a factory loader for your tractor ? Curious what that might be compared to this one.
/ TA-170
Thank you for the response. I should have been more specific in my original post. I guess my own ignorance assumes all of you know what I have!!! I DO have a 72" bucket/loader on my Kioti. I'm new to the world of grapples & tractors & have been comparing skeleton vs bucket grapple vs bucket thumb, something that will work within my budget. I have an accumulation of downed tree tops & logs that existed when I purchased the property, (it had been logged 10 yrs.earlier). The option of using the bucket with the grapple (or thumb w/bucket) is somewhat unappealing due to the amount of dirt & debris the bucket would also gather, not to mention hidden stumps I'm sure I'll find. I guess I'm looking for advice from one of you folks who has better experience or knowledge.
Thanks everyone for the views & I look forward to enjoying more of the interesting, informative subjects on the forum.
Happy Thanksgiving everyone!
:drumstick:
/ TA-170 #6
My understanding is the TA-170 is a complete loader for your tractor. That's why the price is so high as its not just an attachment.
Removing stumps can be a lot of long days with a tractor depending on the size and amount you need to remove. My first thought would be to hire a dozer to clear them if there are a lot of them. The time and wear saved would be worth it in the long run. I do sometimes dig them out with my tractors with the backhoe attachments but most often I use my big international backhoe for anything substantial and when a hole field needs cleared after a logging job the Dresser gets pulled out of moth balls because a tracked loader or dozer will always make the job go faster.
Before buying anything I would make sure it isn't better to hire the job out and use the tractor to do the finish work after.
I think in this case a better description of the task at hand would allow others to chime in with advice as well. Maybe a picture of the landscape to be worked or an estimate on how many and the size of the stumps to be removed?
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
New/Unused Landhonor Mini Skid Steer Grapple Bucket (A61166)
New/Unused...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
