/ Your last generator Maintenance Run #611
Still need to figure a way to alert me when power back on rather than spying on the neighbors. Easier to do in the dark but daylight hours aren't as easy. Hey I know... A good use for my drone with camera on board, except it can't overpower this much wind. Oh well.
I had the same problem during daylight hours. I installed a Reliance Electric Power Back alarm. It runs from a 9V battery and has a lead which senses the presence of power and then sounds an alarm that sounds like a smoke detector. It works like a champ!
You can get the alarm from a variety of on-line vendors, including Home Depot.
While I do like Industrial's roll-your-own approach, this looks like a consumer friendly setup, that should be relatively low cost.
If you've been running one for a while J, is the battery life good ?
Rgds, D.
Power out again today! 50mph winds coming down the throat of the Hood Canal. Generator on and big screen too! Yep, roughing it. Still need to figure a way to alert me when power back on rather than spying on the neighbors. Easier to do in the dark but daylight hours aren't as easy. Hey I know... A good use for my drone with camera on board, except it can't overpower this much wind. Oh well.
Like the commercial says....
Dark night + reliable generator + big-screen......... Priceless.
Enjoy.
Rgds, D.
/ Your last generator Maintenance Run #614
Enjoy.
Rgds, D.
I like it... things are going so well I might just stay off the grid awhile longer than necessary! :D :cloud9:
/ Your last generator Maintenance Run #615
Rgds, D.
The same battery has been in the unit since it was first installed a few years ago and it still works fine... note to self: I really should proactively install a new battery.
/ Your last generator Maintenance Run #616
Low cost is right - $35
/ Your last generator Maintenance Run #617
Just did an oil change 54 weeks after install. Genet had 40.6 hours.
It exercises weekly for 20 minutes, so 18 hours was maintenance. We had one 15 hour outage and the remaining 7.6 was short duration interruptions.
/ Your last generator Maintenance Run #618
On smaller engines I like to keep changes < 50 hours too..... even on a tight budget, until you get into the big industrial units, it's not like they take all that much oil....
Rgds, D.
/ Your last generator Maintenance Run #620
Just did an oil change 54 weeks after install. Genet had 40.6 hours. It exercises weekly for 20 minutes, so 18 hours was maintenance. We had one 15 hour outage and the remaining 7.6 was short duration interruptions.
this just reminded me to run my a bit. Ran the Honda EU2000 for a half hour hooked to about 1500 watts of roof melting cable.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
MASSAGE CHAIR (A58214)
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
