I don't have enough tractor/traction, what now?
   / I don't have enough tractor/traction, what now? #21
I think it really depends on your terain, the driveway material, and most of all how you drive it.
Flat vs. Hills
Paved vs. Dirt
Gentile vs. Street Racer
If you have a hilly dirt driveway where you could get a lot of traction and you drive like the go pedal is a toggle switch then you should avoid it at all costs. For others with calmer temperaments and the right conditions it would likely never be an issue.
You are probably right, but I have seen people that could tear up anvils....:eek:
   / I don't have enough tractor/traction, what now? #22
They shouldn't have to be offset more than about an inch per side. Is that much going to really hurt anything?
   / I don't have enough tractor/traction, what now? #23
Since you have the chains already, I would get the spacers. Chains will make the most difference. I would only chain the rear and let the front slip to relieve binding. You can chain only the front if you're careful with direction changes and let the rears slip to relieve binding. But if you chain both, you can get binding that is damaging to the drivetrain.
I have used front chains only because I had them already from an old truck and I didn't have the clearance in the rear. I never had any problems from using them and the tractor was unstoppable with them on. However, the v-bars took chunks out of my concrete floor in the shed so I stopped using them.
Then I tried grooving all of my tires. It made a tremendous difference for me, even on solid ice. I've never used chains since. Do not get me wrong, v-bar chains are more effective than grooving your tires, there is no comparison. But grooving your tires and then adding weight does a lot. I'd say that a balanced 2WD tractor with grooved R-4 tires can push about as much in packed snow and ice as a 4wd tractor stock R-4 tires. So it maybe doubles your traction. V-bar chains will make your traction go up 10x and thus the fear of breaking driveline parts if chaining all 4 especially with v-bar chains.
   / I don't have enough tractor/traction, what now? #24
I have an L3200 and did not add chains as yet. There are four other Kubotas on the street: two have chains, two do not. One of those two has chains on the front only.
Grooved the R4's before last winter and I was pleased with the traction plowing, though they did not cut it in deep snow in the woods.
When I get spacers I plan to get steel 2" from Stahl.
   / I don't have enough tractor/traction, what now? #25
Ditto chains.
IF your setup works for most of the snowfalls and these drifts are a rare occurrence, leave the front blade in the garage. Dont try to push a bug wall of snow. use the bucket and remove it.
But if this is a common occurrence, blower would be best.
   / I don't have enough tractor/traction, what now? #26
Ditto chains.
This is mostly my thought as well for the short term. But as I have seen big drifts as well and know first hand that you usually have to keep going back at them a few times as the wind keeps building them right back up, the best long term solution is to get a blower as it makes short work of them with no worries about where to put the snow. Also if the blower is heavy you usually don't need the chains even when traction is a bit limited. The few times I have had a lot of tire spin I simply lift the blower just slightly and the added weight gives me enough traction to get going and once the snow is for the most part blown away you can go back and get that inch or two you left and it always seems that I have more than enough traction for that on the second pass. FOr the most part this is a rare occurrence for me even with the 2 wheel drive internationals and to be honest I haven't ever had to install my chains for winter snow clearing and I do some fairly steep driveways with R4 tires on the Kioti and ag tires on the international and deer The deere and Kioti are 4x4 the international is not but it weighs a heck of a lot more than the kioti and deer put together.
   / I don't have enough tractor/traction, what now? #27
IMO, 5 foot drifts requires a blower unless you have a backhoe, you should attack these drifts sooner to avoid this problem. As stated, since you already have the chains, i would go with the spacers, your tractor will enjoy the "wider" stance also.
Well, my plans of finding a cheap blower this summer were derailed on Thanksgiving. On the way to a friends place I found a nice 61" sitting in a field with a for sale sign. The guy didn't want to fire up the tractor while it was this cold, but we agreed on $800, which is better than I've seen in the past year at least keeping an eye on Craigslist. Might have to put a few inches of wings on it or something if I do get the wheel spacers, but it was to good of a deal to turn down. Will be picking it up either today or this weekend. Currently 14f out so I'm not too motivated, as likely is the guy that is selling it.
   / I don't have enough tractor/traction, what now? #29
I never felt adding weight made much difference as far as traction on snow/ice.
Chains make a huge difference.
Yep. And a 2wd tractor with rear chains will perform better on snow/ice than a 4wd tractor with no chains.
I wouldn't chain the front unless I had to. I don't think the OP is in that position. If he had rear chains his problems would be over.
Lastly, it doesn't take much of a chain. A pair of "2 link" crossbar chains will fix the problem.
   / I don't have enough tractor/traction, what now? #30
$800 for a working 61" blower sounds good. The picture is from a distance but it looks good. I bought one for less but I had a lot of rust to cleanup and then paint.
Good find. My only question would be why he wouldn't keep it.
set of 4 sailun 11R24.5 tires (A56435)
set of 4 sailun...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2014 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2014 JLG 6042...
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
