MAX 28XL Air Filter
/ MAX 28XL Air Filter #1
mitchash
Gold Member
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
Has anyone found a aftermarket air filter for there MAX 28? I just replaced mine, it's kind of a cheap paper filter, no inner filter or secondary filter and it was expensive!
/ MAX 28XL Air Filter #2
Unfortunately no. Not yet on that one. I'd certainly like to know myself if you do!
/ MAX 28XL Air Filter #3
my 3016 has an inner filter tube and an outer paper filter. Just today, I got the outer filter but the inner was out of stock at the dealer. I probably won't go back and get the inner for a while as it still looks pretty clean.
The outer filter was over $50 with tax. :confused: I'm going to look for a replacement as well.
/ MAX 28XL Air Filter #4
How often are you blowing it out?
I usually blow the air filter out after mowing or brush hogging, when there is a lot of dust in the air. I had 80 hours on my machine before it needed replacing. The filter seems cheaply made and cost $50.!
/ MAX 28XL Air Filter #6
^ Yeah that! Cleaning the grills, radiator screen, around the battery box is a constant pain when mowing and such. Got to do it every couple of hours or engine temp goes up! I'm on my second air filter after 400 hours, but will need changed again soon. I do blow it off and clean it regularly like you, but its best not to blow it off so often, and can be "over serviced". Just squeeze the rubber dump valve when you do your grill cleaning. And be extra careful with the cleaning. I think the trick is HOW you clean it. Be sure to only use gentle LOW pressure air from the inside out. Don't bang it on something to try to shake the stuff loose. That will do too much damage. Inspect the seals on the ends carefully! Wipe out inside the air can with a damp cloth or paper towel- especially where it seals on the ends. Don't forget to clean the little rubber nipple valve on the bottom. Then put it all together.
There was another thread I found that says the Cub Cadet 7205 has a similar part number with "MA-" before the part number (3546050180025) and the filter LOOKS the same... but it runs around the same price.
http://www.tractorbynet.com/forums/mahindra-owning-operating/93626-air-cleaner-filter-2015-a-2.html
Keep in mind the Mahindra 2015 uses what looks the same air filter part number (3546050180025) as the MAX when you read the thread.
/ MAX 28XL Air Filter #9
/ MAX 28XL Air Filter #13
If anyone wants to save a little money. This is 100% the exact same air filter that is on my Max 28XL. I ordered it just to see as I found it cross referenced with my Mahindra part #. I paid $27.00 for it new....plus $6 to ship. I found them on eBay from a dealer. I'm gonna order about 2 more for the price. 20180919_174826.jpeg20180919_174843.jpeg20180919_174855.jpeg
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
New/Unused Electric Golf Cart (A61166)
New/Unused...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
Volvo L306 (A57148)
Volvo L306 (A57148)
