Cracked bell housing in a 2006 110TLB
   / Cracked bell housing in a 2006 110TLB #51
This happened to me twice; same machine, same model year. First time: 6 months out of warranty, caused by the loader boom stabilizer bolts coming loose and torquing the drive train while lifting an unbalanced load. That was expensive to say the least. The part at that time was $7500 and with the labour and other parts and supplies the bill was $21k. Not impressed seeing as my dealer was aware (by means of a service bulletin) that these bolts had a tendency to loosen frequently. They even commented on a prior service work order that they had tightened them... but didn't bother to warm me of the impending consequences of not monitoring them.
Second time: about a year ago I cracked open the tranny bell housing by carrying loads with the loader and backhoe at the same time. Since the bell housing is the sole top-side front-to-rear structural member of the chassis, I cracked her open like an egg. This time I was bound and determined to fix it myself, even if it took me all winter. JD was not getting any more of my cash! It took me all winter! I split the machine in half in my shop using jacks and stands. I hired a local retired welder to repair the bell housing seeing as welding cast is not a task that the average DIY welder could tackle. It took him 35 hours over two weeks to stitch it back together (it was severed 90% around). The cost was a quarter that of the OEM part and so far it has held... although I'm a lot more conservative with its employment. For added insurance, I installed reinforcing rods top-side, front-to-back between the frame components about 6"/15 cm above the floor on both left and right sides. It took a bit of configuring to make the thing work (and I have to step over it to enter and exit) but it's not too bad.
I have photos of the machine in pieces that I can dig up if it is any use to anyone.
   / Cracked bell housing in a 2006 110TLB #52
I'd like to see pics of the failure and repairs. Do you happen to know what the Deere torque spec is for the bolts? Every thought of Bellville washers to pre load the bolts?
Matt
   / Cracked bell housing in a 2006 110TLB #53
Note to self... never carry a load at both ends at the same time!
I guess the all the forces converge at the bell housing with loaded loader and backhoe?
Loading only the loader or only the backhoe would cause the opposite end to lift as a visual indicated of overloading.
   / Cracked bell housing in a 2006 110TLB #55
I wonder what it would cost to hog one out of billet steel?
   / Cracked bell housing in a 2006 110TLB #56
I would like to see pictures of the failure and fix also. If you have a picture of the bolts that we should check and where the bell housing broke would be great, the bolts sounds like the ones attaching the loaders cast arms. Do you know if JD made any improvement to the design in the later years. I will be checking mine over very close in the next day or two. Thanks for the info.
   / Cracked bell housing in a 2006 110TLB #57
I'm wondering how you guys are getting the torque wrench on the bolts closest to the operator platform? I fiddled around today and could barely get the open end wrench in there. I only found one of the loader bolts to need a small amount more torque.
Matt
   / Cracked bell housing in a 2006 110TLB #58
Matt
Matt,
I did the same as you. I used a 24 mm open end wrench
   / Cracked bell housing in a 2006 110TLB #59
I actually tightened the mast mounting bolts, I didn't even check the those bridal bolts. I figured that since the mast bolts are attached to the bell housing those were the likely suspects.
Matt
   / Cracked bell housing in a 2006 110TLB #60
I check the 2 large bolts on each side that bolt to the Bell/Flywheel housing... never thought to check the others...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2003 Big Tex 10PI...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
