Block Heater - Nebraska
/ Block Heater - Nebraska #1
JMC68301
Nebraska
2015 Mahindra mPower 75P, 1963 Allis Chalmers D-15
Finally made up my mind on a tractor, Mahindra mPower75p. Better half is worried (or maybe not) that I'll be a stranger....
I do not believe mine is coming with block heater assembly. Have asked several dealers along same general lat. and long. if I need and they uniformly suggested with the new engines not needed. I'm dubious because with my old, tractors (and I mean old - early 60s to mid-70s) I knew not even to try to crank if that wasn't plugged in for a few hours in January.
Question, do I have dealer install or not needed in eastern Nebraska?
Thanks
/ Block Heater - Nebraska #2
Up here in Ma, I was surprised when I found out that I didn't even need a battery maintainer to winter start mine. I hard wired a plug on mine so I could plug in a 1 amp charger to keep the battery warm, as a cold battery loses about 1/2 it's cranking power. I used it for a month and on a whim, didn't use it, and found it started just about as easily.
This year I switched to synth oil which should help even more.
Dunno about your particular motor but I thought I would share my winter tractor story.
/ Block Heater - Nebraska #3
You most likely don't need a block heater on a newer diesel tractor. I installed one on my Kubota (2006) and it was a simple task. It heats the engine quick and therefore I would not recommend leaving it plugged in because it would be a waste of electricty. I used mine once since I installed it and that was only because it was there to use. I plug it in for an hour and the engine is plenty warm. A warm engine is easier to start than a cold one, but my cold Kubota starts just fine during the winter. We generally range about 15-20 degrees in the winter here in CT. So do you need one, probably not. Will it help your tractor start easier in the winter, yes.
/ Block Heater - Nebraska #4
Do your temps get down to -20F and lower? If they do, then by all means get the block heater. Don't ask the dealer TELL him that you want a block heater.
/ Block Heater - Nebraska #5
Even if the motor will start without a block heater . You are still ahead of the game pre-heating. Less wear, less oil dilution and less fuel burned. Less time and fuel to "warmup". In particular with machines and vehicles with windshield defrosters.
If you can't afford 1-2 hrs of power and a timer. You should not have a tractor or vehicle .
/ Block Heater - Nebraska #6
To heat or not to heat. Thats a good question. I'm sure the ECU corrects for ambient temp and starting would not be an issue. My concern would be the cold oil. What would Charles Engles do?:):)
/ Block Heater - Nebraska #7
Block heater retails for $133. For that price I'd put it in.:confused3:
/ Block Heater - Nebraska #8
do you worry about cold oil in your car which runs at much higher rpm's than your tractor?
/ Block Heater - Nebraska #9
A real group IV synthetic oil pretty much eliminates lubrication concerns . Group III and mineral oil, take your chances.
/ Block Heater - Nebraska #10
I have it on my Kubota M7040 and use it regularly in NE Nebraska. It seems to start much better and the heater blows warm air much quicker when I am hurrying to move snow to leave for work. I know it costs to run it but everything in life is a tradeoff and this one makes sense for me.
/ Block Heater - Nebraska #11
Block heaters do suck the hydro somewhat, but you don't leave it on 24/7. Just plug it in a couple of hours before you want to use the tractor. I turn my block heater on 4 hours before I want to use the tractor, but I have all day every day to clean the snow away. You might not have that luxury.
Thanks for all the input. I did not realize I was opening a metaphysical can of worms and ethical culpabilities but....
I think I'll go with a block heater but one in the lower radiator hose...not asking...
Thanks!
/ Block Heater - Nebraska #13
Thanks!
Make sure it is a 'circulation' heater then.
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2019 John Deere R-4038 (A63118)
2019 John Deere...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
