check Hydrolyic fluid hot or cold ??
/ check Hydrolyic fluid hot or cold ?? #1
astro1949
i have a 353HST do I check HYD fluid Hot or Cold ? owners manual does not stste..
thanks,
bob
/ check Hydrolyic fluid hot or cold ?? #2
May not matter. Mine does not state hot or cold. I check it both ways and don't see much difference. I know my car has two marks one for hot and one for cold but the tractor shows very little difference when I check it.
/ check Hydrolyic fluid hot or cold ?? #3
I always check mine cold because if it is hot the site glass will always be full.
/ check Hydrolyic fluid hot or cold ?? #4
That's a good question, one I will ask the dealer next time I stop in to say hi. I always check when it's cold but I eyeball it when I put it away and it always looks the same in the site gauge.
when mine is running with FEL up -- level is low ----- when FEL is down --- Level is high normal ----
does this make sense ??
/ check Hydrolyic fluid hot or cold ?? #6
Yes. The cylinder is holding more fluid when it is extended compared to retracted due to the cylinder rod occupying space.
thanks --- ready for winter !
