Too much HP on pto?
/ Too much HP on pto? #1
shui5612
Montreal
2013 Yanmar SC2450, 2008 Kubota ZD326, 1986 Deutz 7085
Alright so I have a question concerning pto's.
Being somewhat new to tractors and only owning one PTO attachment, a 5 foot Harley Rake, it has a recommended PTO hp range of 18-32.
My current tractor has 16pto hp, and having used the rake this summer it did a fair job. I had to slow down abit over roots or rocks, and the weight on the 3PH is about at the maximum lift capacity of my tractor (2012 yanmar SC2450).
Fast forward to today I am looking at a tractor with ~49-50HP PTO.
Is it possible to run that implement and say reduce the engine rpm/pto rpm so that I could avoid damage, or is having too much HP a bad thing? What I'm saying is; most people size their implements to fit their tractors power rating/size but is having "extra" HP for a given implement a bad idea (if it's over the recommended range)
I have run the Harley rake in light sand to level it out while reducing the rpm on my tractor because it managed to keep up easily.
P.s. I understand that if you put too much HP on the attachment it might "explode" but I'm wondering if running the attachment at reduced rpm therefore HP) is safe seeing how rpm does not affect the performance of the implement as much as it would on say a pto generator.
Thanks again.
/ Too much HP on pto? #2
if you had 10,000 PTO horsepower available to run your harley rake it would not matter except in the following way. If for some reason the harley rake stopped turning for some reason and the Shear bolt or slip clutch failed to work for some reason, something has to give. Rake, shear bolt, PTO shaft, but for darn sure the 10,000 PTO horsepower machine is not going to bog down even one RPM. You see where I am going with this?
If the shaft is turning at 540 RPM with a potential of 1 million horsepower or 10 horsepower the implement is not going to know it. You are just not going to bog down the 1 million horsepower power source no matter what happens to the implement. On the 10 horsepower power source it is liable to bog down and the RPM drop or even stall completely the 10 horse PTO. Does this make sense.?
In your case, going to the 40 horse machine, all that is going to happen is the shear bolt is going to break a little easier if implement becomes bound up with a big rock or something. If the shear bolt fails to break, then something else is liable to break. Maybe twist up the PTO shaft or something else. But as long as the implement is operating normally nothing bad will happen by hooking it to a much larger power source. 540 RPM is still 540 RPM, the bigger tractor can just deliver much more torque into a load.
/ Too much HP on pto? #3
x2. :thumbsup: better to have too much then to not have enough. Just leave the implement protection devices in place and you will be fine. The shear bolts/clutch may not like it but treat your equipment well and you should have no problems.
/ Too much HP on pto? #4
... And, to reiterate, that torque is limited by safety devices that are incorporated into the implement hookup.
Wow thanks a lot everyone,
Yes it makes sense now; all of the safety devices will stay on but they will become the limiting factors ( as intended) instead of being limited by them and the tractor.
Thanks again;
Ian
/ Too much HP on pto? #6
Torque is limited by the slip clutch or shear bolt for a single catastrophic overload, but other than those obstructions for which the machine provides protection, fatigue loading limits machine life. Design equations for different components (PTO driveline, shafts, bearings) all differ for calculating life but in general, think of life being reduced by the square of the power transmitted. For example running a PTO driven implement operating at 16 hp will last 4 times longer than one operating at 32 hp. Then again there are some components where the life calculation involves the cube off the load. In this case operating at 16 hp will provide 8 times the life. This is the reason manufacturers place a power rating on their implements. Reducing rpm will reduce your tractor's available power but it may also significantly reduce productivity of the implement. You will do better to take it easy - run the engine to provide 540 rpm at the PTO but drive slower. The shear bolt or slip clutch is still there to protect against a blockage and implement life will be improved.
/ Too much HP on pto? #7
The shear bolt helps but make sure you have a PTO shaft designed for for your HP. You may be running a shaft designed for the HP of your present tractor,
Horsepower Rating and Length shows a series 1 PTO shaft rated for 16 HP, and a series 5 rated for 47 HP.
So if you have a series 1 shaft it might be damaged when you apply just 32 HP to it continually.
It shouldn't damage the implement but when the shaft goes and your out in the field it is not pleasant.
/ Too much HP on pto? #8
The slip clutch adjust may be more difficult with the power increase and may tend to too high an adjustment.
Shear pin remains the same so no problem.
/ Too much HP on pto? #9
If his current shaft works with the implement overtorque safety system it will work likewise on the higher power tractor.
/ Too much HP on pto? #10
Exactly. The only reason to increase the strength of the PTO shaft is if the load that the implement puts on the shaft increases. As an example consider a 4 foot tiller and lets say a hypothetical 8 foot tiller. The 8 foot tiller would put considerable more load on the PTO shaft because the resistance of the tines penetrating the ground and its much larger gearbox resistance would require more torque to be delivered than the smaller lighter duty shaft was designed for. But in this case, his implement load stays the same, only the potential torque delivered by the power source is more. The load is not more.
/ Too much HP on pto? #11
If it were mine I would use shear bolt protection as recommended by the attachment manufacturer. If it has a slip clutch on it now I would take it off and store it. Install the shear bolt set up and use the proper rated shear pins. It can be difficult to set the clutch up, so too tight and you damage the implement and drive line, too loose and you burn up the clutch.
/ Too much HP on pto? #12
I take exception to the statement that a machine will last X hours with lower hp than the same machine with a higher HP motor. All things being equal, there is no more load on the machine with 100 Hp driving than it is with a 10 HP. The limiting factor is the shear bolt or slip clutch so no additional load is put on the machine regardless of HP. There might be additional fuel used to drive it that is not needed, but otherwise one would expect the same lifespan regardless of the driver used. One exception would be if the lowest HP was not capable of delivering the required torque to shear the bolt or slip the clutch when necessary, then the machine MIGHT last longer but I doubt it. Wear on rotating equipment is usually limited to the ground engaging or a part that is contacting some type of wear agent (soil, weeds grass, rocks etc) and bearings. Therefore the wear is going to be about the same based on revolutions and not the driving HP.
That is my two cents.
/ Too much HP on pto? #13
I agree.
/ Too much HP on pto? #14
Is it possible to run that implement and say reduce the engine rpm/pto rpm so that I could avoid damage...
... but I'm wondering if running the attachment at reduced rpm therefore HP) is safe seeing how rpm does not affect the performance of the implement as much as it would on say a pto generator.
What everyone else said about shear bolts and slip clutches. But nobody seems to have addressed these points.
Running at a lower RPM will have little effect on the torque delivered by your more powerful tractor - it will still have plenty of torque at any usable RPM to break your implement if the shear bolt or slip clutch fails to do it's job. So that's not a solution.
I'm not familiar with your harley rake, but many PTO-driven implements do not work well if you drop the RPMs significantly below the rated speed. Among them are tillers, various types of mowers, and chippers. So not only does that not help with the stated issue, but for many implements it hurts performance.
/ Too much HP on pto? #15
However the OP indicated he had to "slow down abit".
Are you saying running the rake at 32 HP will operate fine and not keep busting 3/8" shear pins (implement overtorque safety system) if he has a series 1 PTO designed for 16 HP ?
PTO Shaft, Series 1, 1-3/8 6-Spline, 1-1/4 Round, 51 In. | Agri Supply #61194
I was just recommending he look at upgrading.
Also is his PTO shaft long enough? When I went from my B7610 to my M4700 my shafts were all to short and I had to use an extender, but most of them were series 2 or better.
Fast forward to today I am looking at a tractor with ~49-50HP PTO. <snip>
/edit - for those that don't know the B7610 is rated at 18 pto HP and the M4700 is 42 pto HP, not quite the jump the OP is writing about.
/ Too much HP on pto? #16
OP says nothing about breaking shear bolts. Hes probably having to slow down due underpower. I assume the PTO shaft is paired to the Harley Rake - Probably furnished with it. It would be adequate for the implements intended use load and the safety devices that are a part of it. ... Yes, length could definitely be an issue on the new tractor.
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2022 EZ-GO ELITE...
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
