so I pulled the tank on my JD 755 and found this/best way to clean inside of tank?
   / so I pulled the tank on my JD 755 and found this/best way to clean inside of tank?
Jay do you have any tips regarding removal of the tank? I keep putting mine off because it looks like a bit of work and I have no issues if I keep the fuel level above halfway.
super easy...give me some time to elaborate:thumbsup:
I ended up just ordering a new sender/pickup with screen.for 80.00 bucks I just figured what the heck
I got the tank pretty clean.I was able to get all of the gunk out other than a thin film stuck to the sides about half way up where the tanks opens up to another cavity
I also didn't care the way the inside of my radiator looked so I am dropping the fuel tank and radiator off at a rad shop to be steam cleaned this week
Bought all new fuel lines,filters for all fluids and of course I'm gonna change all fluids while I,m at it
   / so I pulled the tank on my JD 755 and found this/best way to clean inside of tank? #13
I would think so... unless there is corn in the diesel.
Right now I have a 1930 restored Model A pickup that was sealed and the new gas has left about a quart of sealer in the bottom of the tank... called the supply house and was told it's a problem everywhere alcohol is added to motor fuel...
yup, I avoided the problem in my 1931 Model A roadster by dumping in a gallon of phosphoric acid and sloshing it around, and letting it set until the acid dissolved all the rust. I know a lot of people who used the sealer with horrible results when the alky was added, as well as rubber hoses dissolving with it.
I just went out in the garage and reassembled the parts....well most of them to give you a better visual
we will skip past the side covers and grille removal
loosen the 4 10mm bolts holding the hood hinges to the radiator housing bracket.disconnect lights from hood.remove hood
remove 4 10mm bolts holding the fuel tank shroud to the radiator bracket
remove 4 13mm bolts from the fuel tank shroud attached to the frame.disconnect lights harness.remove tank shroud
remove 2 13mm nuts from the bracket in front of the fuel tank
disconnect the two oil cooler hard lines next to the radiator.you will need a 15/16 and 7/8 wrench.I took my time here;) you may be able to skip this step but it didn't feel right leaving them attached
remove the 4 10mm bolts holding the radiator fan shroud to the radiator.slide shroud forward and rest it on the fan
remove both fuel lines from engine side
slowly raise the radiator up about 1'' while pulling the fuel tank outward.that should get you where you need to be.
I went one step further and pulled the radiator to inspect/clean it and replace the fan belt
I have never posted pictures in on how to do anything so I may have skipped a step or you seen something different as i just reassembled it real quick to make a brief tutorial for you
if you have any other questions regarding removal feel free to ask:D
sorry for the sideways photos guys.When I upload them they are all vertical!! not sure whats going on:confused3:
   / so I pulled the tank on my JD 755 and found this/best way to clean inside of tank? #17
Thanks so much! That's a huge public service!:thumbsup:
   / so I pulled the tank on my JD 755 and found this/best way to clean inside of tank? #18
A perfect solution that became a disaster when fuel formulation changed...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
12 ft Shipping Container (A55973)
12 ft Shipping...
2011 KENWORTH T370 (A58214)
2011 KENWORTH T370...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
