FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?"
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #1
jhous
Member
Purvis, Ms
LS J2020H
Just got my tractor back today after having both front axle seals replaced. I talked to the mechanic that did the job and he said the number one cause of seals leaking is breather caps stopping up (On my J2020 it''s the cap on the right side of the axle). He said when the hydraulic fluid warms up it expands (of course) and if the 'breather cap' is plugged up it will cause the seal to leak. I am assuming he means also that the hydraulic fluid in the axle is full.
I don't know. I know I stir up a lot of dust when I use my tractor and it has every reason to get stopped up. If he's right, then I guess checking that regularly should be routine.
What do you guys think?
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #2
I don't buy that on a slow moving tractor
I don't disagree with you but would it not be more a function of the heat (ie. expansion) of the fluid than the speed of the tractor. I know both my backhoe and FEL definitely warm the hydraulic fluid up when I use them a lot. The backhoe really does it because I'm running at max engine rpm (which means max hydraulic pump speed also) while sitting still for extended periods. That makes the fluid very hot and it's got to expand pushing the air out somewhere and if the breather is stopped up that leaves the seals as the next weakest spot. But, that's just speculation on my part.
In any case, thanks for your input. Your thoughts hold as much validity as the tractor mechanic as far as I'm concerned. I've met too many of them that tried to BS their way through a question in stead of admitting they didn't know.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #4
Overheating fluid in the axle housing, with no way to depressurise the air displaced by the expansion of the fluid could blow a seal. If the breather does not allow equalization then something has to give. Axles are only filled to a point where the air pressure can escape via a breather. Usually the fill plug allows for enough fluid to keep the bearings and gears covered in gear oil /hydraulic fluid.
It is possible the axle might have been overfilled or the wrong type of fluid was used.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #5
I don't either. The front axle isn't part of your hydraulic system. At least not on my tractor. And I can't see any way that your front axle components move at any speed that would heat up the 80/90W oil that's supposed to be in the front axle.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #6
exactly
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #7
This means nothing, the whole 'it's not part of the hydraulic system'. It doesn't matter. Heat is generated by movement of the gears and bearings in the axle. Fluids expand from friction and cause a need to vent gases generated by same. Thus without adequate venting something needs to give. In this case it is the seals. End of story.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #8
He said that the breather was most likely the cause and yet did not mention whether he checked it replaced it or possibly cleaned it.
So If his theory is right- the problem may repeat the next time you work the tractor/ front axle hard?? I would want to Know if the breather was even checked, also condition of the support bearings and If there was play in the drive assemblies.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #9
I am taking mine back for the second time for this very issue, first time was about 100hrs. At that time the mechanic did not know what caused it, no play in the axle or bearings, but went ahead and replaced the bearings as well as new seals. Now 140hrs its going back. when I called the dealer to let them know of the problem again, he called the manufacturer, and they told him they have an "updated/newer" seal, which leads me to believe LS knows that there is a problem with the old seals.As far as the vent being plugged up causing it???Maybe, but I'm not convinced. I hope it is that simple, when I get mine back I will look closer into it.
   / FYI: Axle seal leak cause.....INFO from mechanic "Good or bad?" #10
How many other tractors have a vented axle? Have any of you with failed seals checked the vented plug to see if it is actually clogged? Just curious. I know my CIH is not vented.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
