Log splitter control valve - sticking
/ Log splitter control valve - sticking #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I noticed the control valve on my iron oak splitter is sticking on the auto return. So basically when you're finished the splitting stroke and you return the ram its supposed to release the control level at the end of the return stroke. Instead its holding causing the relief valve to engage. A quick tap of the lever releases it but what is causing it to stick? Its only 2 years old.
/ Log splitter control valve - sticking #2
Is it an Autocycle valve? If so it could need tweeking on the detents kickout pressure. I have to do mine every so often.
It could be dirt too. If its not a AC valve (or an ac valve after adjustment), dirt would be my first suspect.
/ Log splitter control valve - sticking #3
The detents are adjustable on most log splitter valves. Who is the mfg.of the valve? If you got a manual with the splitter it should tell you in there how to adjust.
It may be a prince valve. The dealer had to replace it when new because the original one leaked. I don't recall getting a manual for the valve. Can anyone point me in the right direction for adjustment?
I believe it is an auto cycle valve. The ram returns with one flick back of the lever and is supposed to return to neutral
/ Log splitter control valve - sticking #5
The first thing I would do is clean the valve rod where it exits the body with carb cleaner. just spray it good as you work it back and forth and see if that helps. That is what we used when I was a BobCat mec. Ed
/ Log splitter control valve - sticking #8
If moisture got into the back of the valve ome rust or corrosion could form. None of the different brands of splitter valves have a water tight cover on the detent some even have a visible vent groove in the cover.
