Will my tractor handle a post driver?
/ Will my tractor handle a post driver? #1
ezking
Glasgow
Kubota l4600hst
I have a L4600hst 4x4 with loader.
Will this tractor handle a post driver efficiently?
/ Will my tractor handle a post driver? #2
It will handle a small post driver fine, something like a shaver HD-8, maybe an HD-10. If you are talking one of the big commercial grade units that weigh 1000-2000lbs and take big hydraulic flow I wouldn't want to try it.
/ Will my tractor handle a post driver? #3
Just out of curiousity since I know nothing about post drivers...don't they beat the crap out of the tractor?
/ Will my tractor handle a post driver? #4
To minimise any shock loads/harmonic transfer which will potential damage/fatigue the tractor, the post driver needs to firmly positioned & adjusted so the "base" is stable on the ground - follow these simple precautions, & operate the hydraulic control smoothly (not shifting valves fast open to closed..etc.) post drivers are far less stress on the tractor than backhoes, FEL's , PTO post holes diggers or implements like angled graders which create torsional stress....
The downside is correctly set up the post driver will take virually all the stress & have the "crap" beaten out of it, IMO the cheaper drivers don't hold up & prove a false economy in hard ground &/or thumping anywhere near a decent sized hard wood post- if you have a lot of fencing to do in hard ground use a commerical unit : new, s/h,hire the implement, or engage a contractor; otherwise you need to be a good welder, apt at hydraulic cylinder rebuilding & have a lot of time to make running repairs/mods on the cheap drivers.
We always use post drivers wherever possible in preference to PTO post diggers for our rural fencing- a hydraulic operation is far easier on the tractor than most PTO operations - it's also far easy & a driven post makes for a far stronger fence, though all our drivers are fitted with a reversible hydraulic augers to drill a pilot hole first.
Pictured is one of our post drivers, not cheap but the cost is easily recouped in labour/downtime saving in our farming operations (against PTO post diggers & cheap drivers) + these last a lifetime:-
/ Will my tractor handle a post driver? #5
Like Vertical said, you can handle a post driver easily as long as you match the right one to your tractor such as a Shaver HD8 or HD10. Like MBTRAC described, the stands on the driver are on the ground so the stress is directed to the ground instead of to your tractor when you're operating the driver. You can check out the Shaver Post drivers for tractors and Danuser Post drivers for skidsteers on our website to see the specs.
/ Will my tractor handle a post driver? #6
We have a Shaver HD8 which we leave on our old JD 2010. It has no stand and we have operated it suspended by the tractor 3PH to drive hundreds of posts. Iv seen no issue of stress on the tractor. We bought the PD used and I beefed up the connection between the driver proper and its leveling platform because I noted it was damaging itself. I also increased the driver head weight by about 80#. It works well. No repairs have been needed other than to reattach the helper springs that occasionally break at the ends. I would see no problem with using it on our L Kubotas. Stress to the 3PH is well within their capabilities.
larry
/ Will my tractor handle a post driver? #7
I have a Danuser driver and have used it on several tractors without any problem. There is very little jar if any. I have no idea how many posts it has driven over the years.
/ Will my tractor handle a post driver? #8
I'm surprised to hear that these post drivers require substantial hydraulic flow. My understanding was that they used a big spring and the driver's weight to push the post in. I always thought that relatively little hydraulic flow/pressure would be required because the driver could just be retracted slower. Is it just that the spring on the bigger ones is so huge that smaller tractors can't retract it?
/ Will my tractor handle a post driver? #9
The big commercial units we use, apart from many rams for angle/tilt/side shift/level adjustments will operate the hammer at a fairly high speed so a good hyd flow is a benefit (not a necessity) to keep the hammer's "production speed up", where substantial hyd flow is required is to run the hyd drill/auger for pilot holes in hard ground & rock - without good volume/pressure operating this drill can be extremely time consuming & tediously slow - for us, farming is our business, so any labour is a costed input so we're always try to maximise the efficiency of all tasks..
We've also added hydraulic coolers to two of the "fencing" tractors we usually match to these drivers, the cooler pays dividends when drivers are operated all day in Summer operations @ 38C/100F+& also offers benefit when used with other hyd gear.
/ Will my tractor handle a post driver? #10
Shaver HD8 and HD10's will work just fine on limited flow. The lift cylinder is MAYBE 2" bore. They work fine on even less flow than the published requirements. Even with hyd tilt and angle, the cylinders are small and motions are one at a time and generally slow and controlled.
/ Will my tractor handle a post driver? #11
Rick, you are mistaken. The lift "cylinder" is the rod. ... somewhat less than an inch diameter.
larry
/ Will my tractor handle a post driver? #12
larry
Nice to hear from you, Larry.
The bore diameter is greater than that of the rod (maybe 2", maybe less), but the effective piston area of the cylinder is the cross section of the rod itself.
I hope that meets your requirements for technical accuracy.
The point is made; flow requirements for Shaver HD8 and HD10 drivers are minimal.
That is the important part, and I got it right.
Shaver drivers do not require anything remotely approaching what a reasonably well informed person would call high flow rates.
/ Will my tractor handle a post driver? #13
I run a Shaver HD10 on a John Deere 990. According to the Shaver specs, I don't have the recommended hd flow, but it works fine for me.
/ Will my tractor handle a post driver? #14
Yeah, I was pretty sure you knew the rod part, but when you didnt say it it left open the flow issue to those not aware of how the cylinder is internally set up. That setup is what ensures a lo flo requirement. To the uninitiated calculating flows based on a 2" +/- cyl would indicate a huge flow and dumpvalve issue [:confused2:]. Thats why I brought it up.
larry
/ Will my tractor handle a post driver? #15
ezking,
Rear lift (at 24"/610mm): 2,320 lbs [1052 kg]*
HD8 Hydraulic Requirements--- 3-4 GPM/1,500 PSI
HD10-------------------------------12 GPM/1,500 PSI
HD12-------------------------------15 GPM/2,000 PSI
Kubota L4600
Hydraulics:
Type: open center gear pump
Valves: 0 to 3
Pump flow: 8.4 gpm [31.8 lpm]
Total flow: 13.5 gpm [51.1 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
Got a used hd -8. Older model and does not have a stand. Got it plumb to my L4600. Tried it out and I am getting a lot of movement when pounding. So much that it almost missed the post. Any parts that I might need to check out. Or ideas?
/ Will my tractor handle a post driver? #17
I have an HD-8 that I mount on my '65 Ford 2000. I do use the stabilizer bars on the 3 pt. arms. While not totally rigid, I had no problems with it moving that much. I also have a hydraulic top link, which helped in a couple of spots where I needed a little more tilt, to get plumb.
Also I'm sure the flow rate on my 2000 isn't near what it is on your tractor. I set the rpm's at around 1200, and it worked nice and smooth, with no jumping, or jerking.
Not sure how many posts you're planning to drive. Being it is a used driver like I bought, a spare return spring or two may be a good idea. I broke one on mine, while just trying it out. Called the local dealer here, and it would be 7-10 days before they could get one. Did some checking online, and found them at Kencove fence supply in Pa., for 2/3 the price, so ordered 2, and were here in 2 days. Post Driver Springs Drove about 350 posts, with no issues.
/ Will my tractor handle a post driver? #18
Thought you guys might like to see pics of my pounder. It's on a John Deere 3020. I fenced 6 acres. 10 foot high fence.
/ Will my tractor handle a post driver? #19
Very nice. 10' fence... What are you keeping in or out?
/ Will my tractor handle a post driver? #20
Keeping deer out. I wouldn't have gone 10 feet high but our local Department of Natural Resources will provide up to $5,000.00 in fencing materials for free and they require the height. I have another fence that is 8 feet high and have never had a deer get in.
New/Unused Pallet of Ground Protection Mats (A65583)
New/Unused Pallet...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2006 Stephens...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
