Kioti's Radio - Comments Appreciated
   / Kioti's Radio - Comments Appreciated #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I understand that Kioti is now shipping their tractors with an unbranded radio. It is a CD / AM / FM radio with MP3/WMA capability, a front auxiliary & USB ports.
I would appreciate comments about the quality of this radio and/or user experience.
   / Kioti's Radio - Comments Appreciated #2
Mine sounds fine so far. It's what you'd expect. The speakers are small and cheap. But plenty of music comes out.
   / Kioti's Radio - Comments Appreciated #3
Mine is fine--You have to learn how to switch the frequency bands-Korea is not the same as the USA by trial and error but other than that
once you set it you are fine. Get yourself a beer and push the dials and observe what happens;. Discovery is good for the soul.
   / Kioti's Radio - Comments Appreciated #4
The speakers are cheap. I changed mine out to pioneer 3-way 6.5" speakers..sounded better but still not great so I ended up swapping out the Factory for a Kenwood Bluetooth radio..now is sounds great...and Bluetooth my phone rings in and can talk hands free and the wife couldn't tell the tractor was running. All in all a huge improvement over the factory cab NX radio
   / Kioti's Radio - Comments Appreciated #5
Did the 6.5" speakers bolt in or did you have to do any modifications?
   / Kioti's Radio - Comments Appreciated #6
Put in exactly the way the factory ones are. Just cut the opening with a razor blade to accommodate the new speakers, make new screw holes and you can reuse the screws and nuts used on the factory ones. You will need to lift the top to get access to even remove the old speakers so you can hold the nut from turning with the screw. IF you have a second pair of hands you can change them pretty quickly.
   / Kioti's Radio - Comments Appreciated #7
Speed clips are perfect for this. They hold themselves in place.
   / Kioti's Radio - Comments Appreciated #8
Yes, I used some Tinnerman clips on a couple of screws I had difficulty since I did it all by my lonesome..
If you have an extra set of hands outside to pull the magnet and seat the speaker while the inside person aligns, drills holes and puts screw in it can be installed quickly with origional hardware.
   / Kioti's Radio - Comments Appreciated #9
Thanks , i couldnt remember if the speakers were that big or not. Next time i lift the top off i'll install some new speakers maybe, i need to upgrade my front camera and to do so i have to run new cable.
Adams 16T Tender Body (A55315)
Adams 16T Tender...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
