Tl80 wont start after rain
   / Tl80 wont start after rain #1
cjduty1
Have a 2005 tl80 that will not start after a bad rain... The battery reads over 12 v and the horn honks and lights work but it will not crank. I don't get any of the normal warning lights when I put the key in so I think it might be water in some computer thing.. Any one else heard of this?
   / Tl80 wont start after rain #2
Check the connectors looking for leaking into the connector, check the grounds and the safety circuits.
The terminals are tight and not corroded and I looked at the electrical connections to the starter and couldn't really see anything I think I'm just gonna wait till it dries out and try it again
   / Tl80 wont start after rain #4
You generally have a series of switched between the key switch and the starter solenoid ( for example, a seat switch, a pto switch, a clutch or transmission switch, etc) these must be all be closed to close the circuit to the solenoid to actuate the starter motor. There is a chasis ground connection that connects the negative battery terminal to the chasis of the tractor to provide a system ground. these can loosen with time or corrode.
If any of the safety circuit switches are open OR thechasis ground is bad, the starter won't roll the engine over.
   / Tl80 wont start after rain #5
You can take a voltmeter to your safety switches, and check for continuity when they're made.
Chris
2016 Chevy caprice (A55788)
2016 Chevy caprice...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2017 Ford F-550 (A55973)
2017 Ford F-550...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
