Valve adjustment: DIY or Dealership?
   / Valve adjustment: DIY or Dealership? #11
NO.Thats a good point. But how many out there know what the service interval is for there car or mower?
Most cars and trucks use hydraulic lifters and adjustment is not needed. Not sure why some manufacturers use such short adjustment intervals on their engines. Valve wear is usually due to poor or lack of lubrication and can cause more frequent.
I would check them now and then see how far out of tolerance they are. Use this as a benchmark for future adjustments. If still in tolerance I would wait till 1200hrs before I checked them again barring any engine performance issues.
   / Valve adjustment: DIY or Dealership? #12
or inferior soft metals.....neither of which should be in a modern industrial diesel.
In the over 50 years I've worked on cars, I've seldom if ever seen a need for a valve adjustment outside of a worn out engine. Valves will beat themselves into the seats on older cars after many miles/years. I've driven many cars many miles (and still have several) without even thinking about the valves except when it came tie to overhaul.
I still say fugetaboudit.
I certainly can’t disagree with any of those points. I believe most would agree engines will continue to run for many miles/hours on worn valves before any kind of catastrophic failure or need for overhaul, but there WILL BE a loss of performance. My own personal experience tells me there is a lot at play here: valve and cam geometry, ramp speeds, flat tappet vs. rollers, proper cam break in, ZDDP additives, or as pointed out if they are hydraulic and adjustable at all! The list goes on… I’ve also learned “best practices” say you should re-check and re-adjust particularly after a new or newly rebuild engine after break in- the first one being the most important, then you are probably good to go! Things settle, shift, seat, and find a kind of a happy place. Metals will stretch shrink and warp after a few heat cycles. All of this is normal. In fact that’s why there are clearances designed in! Davesl708 is spot on! After I have checked them for myself and benchmarked I may likely not check them again for a very long time baring any issues. I too was surprised to see Mitsu lists checking every 200 hours. I can see checking after the first 200 then every 1000 or so… Could I get by not checking at all? Sure. But I’m kinda particular about stuff like this when it comes to maintenance. Following scheduled maintenance intervals was engrained into me thanks to the U.S.Navy particularly as an aviation mechanic for so many years.
   / Valve adjustment: DIY or Dealership? #15
From one aircraft mechanic to another................THANKS for you service.
hugs, Brandi
   / Valve adjustment: DIY or Dealership? #16
My 6520's manual says every 1000 hours. Good thread. Glad you started it. I am just over 1000 hours now.
So mine is do a clearance check.
hugs, Brandi
   / Valve adjustment: DIY or Dealership? #17
You aircraft mechanics live in a different world, Brandi. Maintenance intervals are not
optional.
I once had a friend whose plane owner-partner did a sloppy landing where a prop barely touched the
runway (2-engine plane). They were required to rebuild the engine, even though it
ran fine. Rules.
   / Valve adjustment: DIY or Dealership? #18
optional.
ran fine. Rules.
Yep...........if one tire of two tires on the same axle gets below a certain psi............you gotta change both tires.
hugs, Brandi
   / Valve adjustment: DIY or Dealership? #19
Its what you got to do when pilots lives are in you hands. you all heard the saying".The rules are written in blood"
   / Valve adjustment: DIY or Dealership? #20
So true. If the engine fails or a tire blows out you don't get to coast over to the side of the road with a plane.
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
