ZTR slides down hill and over wall, driver was saved- very lucky
   / ZTR slides down hill and over wall, driver was saved- very lucky #61
What are you comparing a ZTR to to say it has a high center of gravity? My ZTR has a lower center of gravity than any other mower I have. This includes a F series Kubota, a Kubota G3200, a John deer F525, a B7200, and a regular riding mower made by Cub cadet. A ZTR can't compete with a real slope mower rated to something ridiculous like 45 degrees, but with locking front wheel would do better than a regular riding mower.
you might be right on the lower center of gravity for ZTR's 60" or larger, but there are plenty of smaller ones that have both narrow & short wheel base...add the rider weight and sometimes hyper sensitive hydro, and you have a dangerous situation on a wet slope. my only point i guess... but i still don't buy locking ft swivel wheels, too dangerous. :)
   / ZTR slides down hill and over wall, driver was saved- very lucky #62
My ZTR has a 50" deck, and weighs 1200 pounds. I use it to mow the bottom of ditch lines. It is hard to slide down a hill if you are already at the bottom. About the only way to flip a ZTR would be to slide off a wall like the victim in the op's post. If you did manage to flip a ZTR without sliding off a wall, it would take a slope far steeper than any other machine we have would take. I don't think a ZTR could stay on a slope steep enough to turn it over even if it was pavement. Locking swivel wheels might not turn it into a real slope mower capable of 45 degree slopes, but it would certainly be better than just swivel wheels.
   / ZTR slides down hill and over wall, driver was saved- very lucky #63
my guess is that you're a more skillful mower operator than the average home consumer and can get away with it.... but any riding mower (unless commercially equipped for slopes), is potentially dangerous on "excessive & wet" slopes for most home consumer operators.
   / ZTR slides down hill and over wall, driver was saved- very lucky #64
That may be true. There is a mild slope in the backyard that gives my sister fits on the ZTR. She can accomplish mowing it much better on a regular riding mower. I can mow that hill and much steeper hills on a ZTR without problems as long as it is dry.
   / ZTR slides down hill and over wall, driver was saved- very lucky #65
fair enough..... & enjoy the mow, before robots take over. safety first!
   / ZTR slides down hill and over wall, driver was saved- very lucky #66
Like I mentioned earlier, I knew if a guy that flipped one over in a pond. He laid in comma a cpl days before dying because he couldn't get seat belt unhooked. Good idea to keep a knife tied to ROPS or somewhere close to belt. They're very hard to unlatch with weight hanging on them. Believe me I know. The hard way.
   / ZTR slides down hill and over wall, driver was saved- very lucky #67
Also a good reason to frequently lubricate the latch. I try to do that at least once a year for our machines as otherwise the latches stick.
Aaron Z
   / ZTR slides down hill and over wall, driver was saved- very lucky #68
I feel much safer on my Gravely ZTR than on my piece of crap Husqvarna YT lawn tractor. No comparison.
   / ZTR slides down hill and over wall, driver was saved- very lucky #69
i can understand why, gravely makes a quality ZTR. a consumer grade mower from lowes & such wouldn't last a year on my property.
   / ZTR slides down hill and over wall, driver was saved- very lucky #70
The ROPS on the ZTR is lower than the roof of the truck. Where are your driving, and with what?
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2008 KENWORTH T300 (A58214)
2008 KENWORTH T300...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
