John Deere 3020 Diesel
/ John Deere 3020 Diesel #1
JDhobby
Kelowna, B.C.
I have a 1965 John Deere 3020. When the tractor runs at a low idle there is a rattling or knocking noise coming from the front of the engine. When I turn the steering wheel it is louder. when I run it at a higher idle it seems to go away. Could this be the hydraulic/steering pump or do I have bigger issues? New member, first post.
/ John Deere 3020 Diesel #2
Hi. Welcome. I am not familiar with your tractor but several on here have 3020's and could help.
/ John Deere 3020 Diesel #3
Welcome to the forum!
:welcome:
I'm going to move your thread over to the vintage John Deere section. Hopefully someone over there knows.
/ John Deere 3020 Diesel #4
Welcome to TBN
Noise you describe is normal for worn hyd pump drive bushings/plates. Check frt hyd pump drive coupler bushings for wear.
Welcome to TBN
Thanks for the info. I suspected it was the pump. I'll check and see what shape the coupler bushings are in. Appreciate the feed back.
