Oil & Fuel Hyd oil drain questions
   / Hyd oil drain questions #22
Well that is what we call "totes" around here... English is a wonderful language, we have so many regional variations even here in the US, we can barely communicate with some areas. Let alone you guys in other countries, when it comes to naming things, I am certain that I would be scratching my head trying to decipher some of your local names for objects. But in any case, yes a large plastic storage container is what I had in mind for catching 10+ gallons of hydraulic fluid.
I don't know about your tractor, but the Kioti has a huge main drain plug in the middle of the transmission, and the flow rate is very rapid. Then you have the rear final drive plugs on the rear axle which are much smaller plugs.
More than likely. In fact I'm reminded of a visitor from America who was staying with some acquaintances I knew from a local pub. He told me that someone asked him if he would like a biscuit and he didn't have a clue what a biscuit was. To him it was a cookie!!
As for my tractor there are two drain plugs for a common sump for the hydraulics, transmission (HST) and rear axle.
Sterling AT (A56435)
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
16001 (A55853)
16001 (A55853)
Flat Bottom Grapple (A56857)
Flat Bottom...
Massey Ferguson 9250 (A56436)
Massey Ferguson...
