Oil & Fuel Hyd oil drain questions
   / Hyd oil drain questions #11
I've got a couple of hundred hours to go before I have to do the transmission fluid on my rig... does the 'run the tractor for a while to warm up the oil' trick work the same for the tranny?
(PS: James, I'm not in the US either... :laughing:)
Oh sorry, did not notice. BUT I am sure they have something like a 'tote' in the UK.
Just did a bit of research and I see what you mean now. A more stable container.
I'd say so. Thins the oil for a better flow as well as getting all the bad stuff in suspension.
   / Hyd oil drain questions #14
Ta, Mate. I thought so but, never having done that particular evolution with that particular type of fluid, it never hurts to ask. 'Tricks for young players' & all that.
I also had to Google what a 'tote' was... which goes to the quote at the bottom of your entries, eh?
   / Hyd oil drain questions #15
Personally, I like using 5 gallon buckets, with snap on lids. I have several I use for oil changes, and they make it easy to haul to the oils recycling places. I usually have a couple that I add oil to, from small engine changes, that are sitting in a corner with lids on them. Then after I do the larger changes from tractors, I haul them all in to empty the buckets.
   / Hyd oil drain questions #16
A "tote" is just a large plastic storage container, usually comes with a snap on lid, but we don't need the lids for our purposes. Usually not so tall that they fit nicely under our tractors, yet will easily handle 10 to 15 gallons of fluid, are usually rectangular in configuration and usually pretty cheap to buy, at least over here. They are certainly not made to catch oil by design, but there is no reason they cannot be used for that, and I keep one in the barn just for that nasty purpose.
Perhaps I ought to make it clear that I'm dealing with amenity i.e. football/soccer pitch rather than agriculture.
I did ask for lids for my buckets but there weren't any. Precisely for the sake of transporting them to a recycling area.
When I Goooooooooogled 'tote' I got told about Tote betting and women's handbags!!! :eek: :laughing:
It was only at the bottom of the page that I spotted 'tote tanks' and that made a lot more sense!
   / Hyd oil drain questions #18
I just recently changed mine for the first time. I drove the rear wheels up some ramps and put a 5gal bucket under each drain. Worked fine and is cheap. The buckets are everywhere.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
