Oil & Fuel Hyd oil drain questions
   / Hyd oil drain questions #1
Hieronymous
Wigan, U.K.
New Holland TC40DA, Sisis Quadraplay, John Deere Aercore 1500, Flail Mower
I am preparing to change the hydraulic oil on my TC40DA HST for the first time. There's nigh on 10 gallons of the bloody stuff in there so I've got two large receptacles each of which should hold in the region of 5 gal. This, though, presupposes that I'll get an equal amount of oil from each drain plug which won't, necessarily, be the case
Is it likely that I'll get a greater amount of oil from one drain plug than the other and, if so, which one?
Also, is it better to drain from one plug at a time (if so, in which order?) or drain both at the same time?
Wise counsel appreciated.
   / Hyd oil drain questions #2
It’s not that complicated. Put a bucket under one plug and drain. If it starts to get too full, slide that bucket out and put the empty one there, it’ll slide easier than you think. Once that drain is done, slide the bucket over and drain the other plug.
Thanks for the reply. So do them one at a time. It's just a case of forewarned is forearmed. Just need to find somewhere to put the tractor so's I can get the buckets under. They're just a fraction too tall!! :mur:
   / Hyd oil drain questions #4
Go to dollar general or Walmart and get a 62 quart tote . forget the bucket.
Unfortunately that wouldn't really be cost effective!! ;) :laughing:
   / Hyd oil drain questions #7
Totally agree. Less than 10 bucks, bigger opening to catch more mess. Ample capacity. Those are all I ever use for automatic transmission services anymore.
   / Hyd oil drain questions #8
He's not in the U.S.
Lay down some planks/boards flat on the ground for each tire and drive up on those for height. I'd use 3 buckets, and slide them out when partially full so they are easy to handle. You still might only need 2 if doing the one plug first. It's not that bad to do.
   / Hyd oil drain questions #9
Oh sorry, did not notice. BUT I am sure they have something like a 'tote' in the UK.
Thanks guys. I got a couple of plasterers buckets and, at £7.50 each, I'm going to get some usage out of 'em!!
I don't know what a 'tote' is. Presumably we know them by a different name. Anyway circumstances and weather may prevent me from doing this for a while.
I've changed the oil on my car numerous times but my concern here is with the amount of oil.
2014 Toro Groundsmaster 4500D Commercial Rotary Mower (A56857)
2014 Toro...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
