3016 First full hydro change at 100 hours
   / 3016 First full hydro change at 100 hours
I filled it up and then drove it around the yard, then checked the drain holes and it poured out. So I guess it gets where it needs to.
Don't worry, just take out the 2 'vent' bolts to allow the air to exit while filling, and fill the fill hole to the top. It's all good.
   / 3016 First full hydro change at 100 hours #12
Thanks again for all your help and info
Sent from my iPhone using TractorByNet
   / 3016 First full hydro change at 100 hours #13
SO you didn't just fill it up at the big hole in the floorboard? You can put it all in right there and check with the dipstick.. crank it then run all hydraulics in and out to bleed air and then check once more
Yes, that takes care of the rear end of the tractor and the fel, etc but not the front axle. That has a separate fill, vent(s) and drain(s) holes. No dip stick, just a fill hole.
   / 3016 First full hydro change at 100 hours #15
Ohhhhhhh ok I thought you were still talkin about the rear... that's my bad. Don't really understand the point on the front axle change other than cleaning out assembly trash... bet that oil looked as clean as the stuff you put back in huh?
It looked clean, for sure, but since this was the recommended first time change out, I felt it was necessary.
   / 3016 First full hydro change at 100 hours #17
The fluid level is listed somewere in the manual I believe if not on the parts list... 4.2qrts If im thinkin right
   / 3016 First full hydro change at 100 hours #18
Good piece of mind for sure
   / 3016 First full hydro change at 100 hours #19
Really the fact you can use the same oil as the Hyd/Trans takes... makes oil storage easier and less complicated.. that's one of the more operator friendly models to keep up.. gona miss those 16 series
   / 3016 First full hydro change at 100 hours #20
I have a vintage Alemite fluid pump that still works great. Each crank of the handle pumps about a pint. When I changed mine, I went through almost all of three 5-gallon pails of hydraulic oil. The tank on the Alemite pump has a large fill cap so dumping oil into it is easy.
Mine is same as this one but with a few dents in the tank. It's a time and mess saver.
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
405 (A52706)
405 (A52706)
1997 Take 3 Auto Transport Trailer Trailer, VIN # 1C9TT5036VB409167 (A57453)
1997 Take 3 Auto...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
