Where Do You Guys Mount Your Shovel and Rake
   / Where Do You Guys Mount Your Shovel and Rake #1
drizler
You just gotta have a shovel and rake when working in the dirt, at least I do. I used to have a piece of 2" pipe welded across the arms of my ancient POS 230 Farmall. Not like I am going to do that sort of thing to my new one. So with an open station rig like I have on the picture in my avitar what's out there and where can you mount a couple mounts for a shovel and rake. I can carry one or the other in the bucket of the back hoe but both won't fit and stay put. Otherwise there isn't much space to put anything:confused:
   / Where Do You Guys Mount Your Shovel and Rake #2
Vertical tubes on the loader mount.
Bruce
   / Where Do You Guys Mount Your Shovel and Rake #3
Bruce nailed it. After years of balancing a shovel on the 3 point implement, or in the bucket (remember its there before using loader!) I took a scrap piece of 1 1/4" pipe and some other appropriate steel stuff, and tapped two existing holes in the back side of my loader mount. Ta dah.
   / Where Do You Guys Mount Your Shovel and Rake #5
The reinforcing tube between the FEL arms is a handy place for shovels, etc. Bucket needs to be wide enough that the tools don't stick out to the side. A bungee keeps things from sliding out as you go.
   / Where Do You Guys Mount Your Shovel and Rake #6
I mounted mine on the back of the tractor with a 4 point subframe. The type of shovels the rest of you guys are talking about are way too much work.
   / Where Do You Guys Mount Your Shovel and Rake #7
That's how I do it too. Rake goes in the grapple tube and shovel in the loader tube. Old pic w/o shovel
gg
   / Where Do You Guys Mount Your Shovel and Rake #8
I'm with you on that shovel. The rake is on the loader (rachet rake).
   / Where Do You Guys Mount Your Shovel and Rake #9
My little John Deere 400 loader has a round hollow cross brace down toward the bucket. I throw my shovel thru there. Very handy.
   / Where Do You Guys Mount Your Shovel and Rake #10
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
2015 Ford F-250XL (A57148)
2015 Ford F-250XL...
Rotary SPOA9-200 Automotive Lift (A56858)
Rotary SPOA9-200...
Dorsey Ottawa Spotter Truck (A57148)
Dorsey Ottawa...
2014 MACK CXU613 MID-ROOF SLEEPER (INOPERABLE) (A58214)
2014 MACK CXU613...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
