d'oh!
/ d'oh! #1
mendodave
Member
Little River, CA
Kubota BX23
I knew it would happen, eventually.
I nailed a pruned rhododendron while going around digging them up with my tooth. just under a half inch hole in the rear tire. Is that too big to plug?
Fortunately I have a set of spare wheels....:)
MenD'oh Dave
/ d'oh! #3
Tube it,better to be safer than sorry.
/ d'oh! #5
Put a patch on first or the tube will try to come out the hole.
/ d'oh! #6
ditto with needing to place a patch on first on the inside of the tire. a larger patch, maybe even a little thicker might be wanted. and then tube tire.
had a tire dry rot on me. and over a day the tube pushed out or should say ballon'ed out a few feet in diameter and finally popp'ed. the larger patch = help hold the patch in with tube, and thicker patch = help keep something coming through and puncturing tube at later time.
/ d'oh! #8
ditto with needing to place a patch on first on the inside of the tire. a larger patch, maybe even a little thicker might be wanted. and then tube tire. had a tire dry rot on me. and over a day the tube pushed out or should say ballon'ed out a few feet in diameter and finally popp'ed. the larger patch = help hold the patch in with tube, and thicker patch = help keep something coming through and puncturing tube at later time.
Not poking fun at you Boggen, but darn, just reading about the slow growth of a tire tube to a giant ballon and its sudden demise brought me to tears laughing. I guess I watched too many cartoons as a kid :)
/ d'oh! #9
You might call a local tire company that does ag tires. They sometimes can do a "vulcanizing" repair, it will be a plug that goes in there. I'd still boot it.
/ d'oh! #10
*rubs chin* *chuckles* ya you pretty much got it. it went from simple tire to large growth on tire. never would of imagined a tube would do that. but it did. much like some cartoon! *shakes head in dis-belief*
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2022 EZ-GO ELITE...
Used Landpride GR1525 Stump Grinder
Used Landpride...
