LD1
Epic Contributor
LD, maybe I missed something but you said "It will have 12' of run, the a push-trolley on the 38' span" Why don't you turn the design and make the 12' span the bridge and put your posts in the other direction so that you can use smaller material all the way around??
Also, your deflection calculation is most likely going to control your beam design as long as their isn't a localized failure in the flanges of the beam due to the high point loading from the very small trolley wheels. Also, don't forget that if you have to much deflection center span, that the beam could potential rotate off the running gear at the ends or at the least bind it up. Also, don't forget to look at lateral torsional buckling when you get tall slender sections.
Not sure what you mean by turn the design.
Picture this....I need a crane that will travel 38' north and south, and 12' east and west.
My current plans are to have 4 posts set making a 12'x38' rectangle. Going to set an I-beam with 40# rail track on top of the posts spanning the 12' direction, then a large beam to make the 40' span with the push trolley.
Swapping the design and going with TWO beams to span the 38' is going to require MORE material, as both beams would have to be fully rated for whatever load, and almost 80' of rail track which I dont have, I only have 30'. And I would have TWO permanent beams that could get in the way if backing the backhoe in. With a single beam spanning over top of my work area that is movable, I can always push it all the way to the back if needed.
As far as the calculations, Deflection is a NON-issue with any of the beams I listed in the first post. With the 5:1 safety allowing no more than 7200psi stress, deflection on any of them is under 1/2". It takes dropping all the way down to a 14" beam with only a 3:1 safety factor before I even get to 1" deflection.
So I guess by design, the 5:1 safety factor does limit the deflection right there. Example: a light W12x26 beam under static conditions, failure point of 36ksi is 10,500#. But 3.4" deflection. So yes, deflection is a factor, but not using a 5:1SF.
The torsional buckling is why I dont like S-type beams. Especially with a load dangling from a chain.
