brake line replacement
/ brake line replacement #1
frmboy
howell, mi
JD 5400, IH1466
I replaced the right brake line on my JD5400 a couple days ago. but after useing it for a few hrs, the brake pressure is worse than before I replaced the leaking line! so I presume I have air in the line. (since it's a one-way line) am I right? I think I'll treat it like a normal brake line.
/ brake line replacement #2
Did you bleed air out by loosening bleeder(parts key 4)? Bleeding should be performed with engine running.
Wow! What a difference! That worked very wonderfully. I did have someone press the brake peddle as I opened the bleeder just to make sure I was good. Thanks for your advise.
I'm not sure how long I would have struggled with such a simple problem. Now I'll get back to work, thanks again for your input.
Redball 6 Row Hooded Sprayer (A64119)
Redball 6 Row...
Anderson 24' Tilt Trailer (A64126)
Anderson 24' Tilt...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
1994 New Holland 580 Square Baler (A63688)
1994 New Holland...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
