Electrical problems
/ Electrical problems #1
stephen1956
Grandview, TX
New Holland TC21D
My 2000 New Holland TC21D stop running, battery is good ignition switch tested okay, when I turn the key on I get no dash board lights. I am sure it is a relay just not sure which one or how to locate it with out a schematic. Any*ideas? Thanks
/ Electrical problems #2
:welcome:to TBN neighbor from Coyote Flats,Tx
Have you cleaned tightened all FOUR battery cable connections? Sometimes ground(negative) battery cables connections are overlooked only to determine they were the problem.
Jim
Jim
TxJim, thanks for your replay. I changed the negative cable and cleaned all the one you referenced. I talked to NH this morning and they said it might be a linked fuss located near the starter but I can't find the dang thing. The search goes on. Again thank you.
/ Electrical problems #4
My next guess would be the fusible link that Messicks stocks 6(six) of which indicates fusible link is a high turnover parts item.
