New Holland 451 Mower Angle Question
   / New Holland 451 Mower Angle Question #1
aquaholic
pittsburgh, pa
1961 minneapolis moline jet star
I am looking to replace my minneapolis moline model SO sickle mower with a new holland 451 and i have a couple of questions. all of my mowing is road trimming up against hill sides and 100% of my mowing is done at between 70 and 90 degrees vertical. on my current machine i can move the sickle angle hydraulically between 90 degrees vertical and flat without getting off of the tractor. is it possible to move the sickle angle between 90 and 70 degrees without getting off of the tractor with a new holland 451? i included a picture of the rig i was using for comparison. i would be hooking the NH-451 up to a ford NAA.
ok so i guess i'm kinda committed to fixing the blade at a 90 degree angle with a bracket and using the sickle bar in that fashion. i can't seem to find another solution other than buying a 3 point boom mower that i can't afford. would the NH 451 be my best choice for doing this or is there something better and affordable out there that i am missing?
   / New Holland 451 Mower Angle Question #3
You are going to be hard pressed to find a mower that will work better than the one you have. why not fix the one you have? Ed
it's gone. i sold it last friday. it was broke beyond repair.
   / New Holland 451 Mower Angle Question #5
I wouldn't trade my 451 for ANY other mower, it's pretty much as good as it gets...
SR
the only thing that makes me even a little leary about sickle bar mowers is there ability to operate at a 90 degree angle. thats where i do all of my cutting. the action of that SO mower on my moline was so violent that every time i used i would come back with parts that fell off of it after only 20-30 minutes of use. i finally lost so many that i couldn't keep it running any longer.
   / New Holland 451 Mower Angle Question #7
MY IH 1300 with the rowes hydraulic kit will cut at 90 vertical if I wanted too. Right now I am just wanting it to cut laying flat...had big issues this weekend.
   / New Holland 451 Mower Angle Question #8
My 451 will run in any position i've ever had it in, including the position it's in, in this pict.,
I even have a piece of flat bar that I made, to hold the bar straight up, so I can drive along my lanes, trimming the sides...
SR
   / New Holland 451 Mower Angle Question #9
i have had my 451 for six years and love it
   / New Holland 451 Mower Angle Question #10
I'm fairly new to my 451 and have been satisfied with it. But I would love to see some pictures of the rigs you all use that allow you to mow at a steep angle so as to trim up trails.
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
22' x 23' All Metal Garage (New/Unused) (A59225)
22' x 23' All...
GRILL GUARD FOR JOHN DEERE 5000 SERIES TRACTOR (A52708)
GRILL GUARD FOR...
204158 (A57193)
204158 (A57193)
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
