Ls 3039 front axel breather and dip stick
   / Ls 3039 front axel breather and dip stick #1
old gray
mass.
ls 3039 gear
My owners manual shows a dip stick on the right outer front axel area. Mine has a plastic breather. Part of it may have broken off. I am concerned that water will get in
it. Also I ordered a dip stick to replace it. I am now thinking that it needs to breath, so I better not plug it with a dip stick. ( The dip stick screws into the axel and seals it tight) Any one have any info on this? Thanks in advance.
   / Ls 3039 front axel breather and dip stick #2
The blue cap on the right does not come off (or isn't supposed to). On the top of the left there is a big bolt ... that is the dip stick. Once you unscrew that big bolt on the top you will see a rubber seal and a dip stick with hash marks on it to determine the fluid level.
Thanx, My manual shows the dip stick where the blue cap Is. I thought that may be the case that the dip stick was on the other side. I could not get it loose. I will try harder. For your info the blue cap has threads and does unscrew. I think top part of it is broke and missing not sure what it is supposed to look like. There are 2 small holes in side the top. Seems like it is a breather and maybe a small foam type pad or something should be inside of it.t
   / Ls 3039 front axel breather and dip stick #5
Here is what mine looks like:
   / Ls 3039 front axel breather and dip stick #6
You can use the dip stick on either side ---------
   / Ls 3039 front axel breather and dip stick #8
Ahhh, I tried to take mine off and it wouldn't budge and with it being plastic I was chicken to push it so I left it alone.
SCREENER (A58214)
SCREENER (A58214)
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
