Weed Whacker Kwik Loader or Bump Feed Head?
/ Weed Whacker Kwik Loader or Bump Feed Head? #1
troverman
Gold Member
NH
Kubota MX6000 Cab
I have three trimmers - a 2004 Honda 25cc 4-stroke, a 2013 Husqvarna split-shaft with Honda 25cc 4-stroke engine, and just yesterday, a new Honda 35cc 4-stroke with the bike-style handlebars. So you can see what my trimmer preference is, anyway.
That aside, every trimmer I've owned has either had the usual bump head, or some kind of a fixed blade, be it plastic or steel.
This new Honda has a Kwik Loader head with two little pieces of string hanging out of it. I'm totally confused. Do people use this? I had to go online to even read what the company thinks the advantage is - they say, it saves time over winding up a bump head with string. That may be true, but a lot of my trimming jobs simply eat through string. Trimming gravestones at a municipal cemetery, trimming along concrete walls, or chain link fences...its just inevitable to need more string advanced. With the bump head, it take me 5-8 minutes to unwind new string, rough measure it, cut it, wind it on to the spool, and then start trimming again. A fully loaded spool will get me through a whole cemetery, or quite a few other "normal" jobs. The Kwik loader seems like I'll be replacing string every 5 minutes! The string is the same and will get eaten at the same rate, yes? So I have to shut down, disconnect from harness, stand trimmer up on its engine, and then replace the string with pre-cut new string. And then throw away the excess. Seems like the bump loader is a lot less of a hassle. The Husqvarna head is easy to load and spool out string than the Honda bump head.
/ Weed Whacker Kwik Loader or Bump Feed Head? #2
I did not think I would like the bump head I got on my Stihl 13 years ago, but I swear by them now. I have worn out several through the years- I keep the spool and load those. When I am out of line, I just replace the spool with a pre-loaded one from my toolbox.
Will
/ Weed Whacker Kwik Loader or Bump Feed Head? #3
I have a John Deere trimmer that is about 25 years old (and still going strong). I have both a bump head and the type you thread a short section of line through. On mine the thread through type allows a much heavier line. The bump head takes .095 line while the thread through uses .155 size. I use Oregon Gator Line in .155 and it really lasts. I even knock down a lot of brush up to 3/8 inch diameter or more.
/ Weed Whacker Kwik Loader or Bump Feed Head? #4
Shindawa/Oregon/Echo SpeedFeed head is what I use. Super easy loading.
Those ones that take the pre-cut line are supposed to be the newest greatest thing, but I thing Id spend too much time replacing short pieces of line vs tapping the head on the ground/ Dealer was pushing them when i bought my last Speedfeed
/ Weed Whacker Kwik Loader or Bump Feed Head? #5
We tried a head that sounds like the Kwik Loader on a trimmer at work and the guys didn't like it at all.
I recently bought a different trimmer for here at home because of some heavier cutting that was taxing the string trimmer. It's a Stihl Kombi with what they call a power scythe. It really does the trick on the heavier stuff. It cuts woody things at least as thick as your thumb. Since it shears the weeds like a sickle bar it doesn't throw the clippings all over you. Whenever I use the string trimmer it looks like I was doing battle with a food processor.
/ Weed Whacker Kwik Loader or Bump Feed Head? #6
I do not have experience with the new heads, but in trimming around hard objects .the thick string will break whilethe narrows string will bend and last longer
That's a nice setup. I looked at the Stihl Kombi but went with the Husq mainly because of the 4-stroke Honda. I wanted a power broom; combined cost for the trimmer and broom was about $800.
/ Weed Whacker Kwik Loader or Bump Feed Head? #8
Those fixed line heads are money makers for the consumables suppliers. They don't last as long and they cut poorly. The bump head is the way to go, but I am going to go check out the power sickle. I like it immensely....If it does what is said that might be my new weed eater.
/ Weed Whacker Kwik Loader or Bump Feed Head? #9
This!! I have used mine hard on an older John Deere commercial trimmer and it works great. Just cut off about 10 feet of line and twist the head to roll it in. Easy and it has held up for me and I'm hard on stuff.
/ Weed Whacker Kwik Loader or Bump Feed Head? #10
I've owned and used a variety of gas powered and corded electric string trimmers, but all with the bump head except one. One of my daughters bought an auto feed; just keep going, no stopping to bump the head and the first time I used it, I thought I wanted one . . . . until . . . . it ran out of string. Every time I used that thing I went through an entire spool of string.
So my current Stihl is more than 10 years old, still using the original bump head. I thought I would like one of those that you don't have to take apart to put new string on it. But my Stihl dealer told me I wouldn't be happy with any of those heads except the one I have.
Well, it looks like I'll be in the market for one of these speedfeed heads, then.
Thanks for the info.
/ Weed Whacker Kwik Loader or Bump Feed Head? #13
Chim, does that power scythe cut thicker stuff than their hedge trimmer cuts? And will it cut grass ok? I've got a Kombi 130 and I've thought about getting the articulating hedge trimmer to use for cutting stuff in places I can't get with my rotary cutter, but the power scythe looks interesting too.
/ Weed Whacker Kwik Loader or Bump Feed Head? #14
I've got one of the Echo trimmers with the Rapid Loader heads that uses 2 pieces of line. I like it a lot. I use .130 line and it lasts a LONG time between changes, even using it around fences posts and concrete headwalls and culverts.
/ Weed Whacker Kwik Loader or Bump Feed Head? #15
Youll like it.
Make sure you get the correct one. There are a couple variations. Some have more capacity and some are brand specific and some are universal. All are the same basic design, but the adapters that fit the gearbox on the trimmer are different.
For example on my Stihl, I have a Echo branded Speedfeed, that was sold as a "universal" kit. It comes with all the adapters for (almost) all the different gearboxes on the market.
On my Honda I have a Oregon 450 Speedfeed universal, that has a larger capacity (4.5" dia, PN 55-265) than the Echo"400" model on my Stihl. One nice thing is that once you have the adapters from a universal set, you can buy the cheaper model specific kits and swap in the correct adapter for your trimmer. The large Oregon model is also heavier duty than the Echo 400 model, with replaceable eyelets where the line exits. Its also considerably more money however, close to $55 vs the $30 for the Echo up here.
/ Weed Whacker Kwik Loader or Bump Feed Head? #16
I haven't used the hedge trimmer so I can't really compare the two. I used the scythe on the bushes at a neighbor's place and it worked real well. I did do quite a bit searching and reading before the purchase and from what I read the blades are very similar and differ in length. The gear box of the power sythe is supposed to be a bit more robust. I visited a real hardware store nearby and mentioned that to their Stihl guru. He said he thought the gears were the same and it bugged him enough to go have a look at the part numbers. He called me later with an answer to another question I had and confirmed there was a difference between the gears of the trimmer vs. the scythe. The scythe has a stainless bottom cover that serves as a sort of skid plate because they expect it to be drug along the ground.
The scythe performs best on anything heavier than lawn grass. It worked OK on grass but the old Stihl string trimmer is a lot faster on pure grass. I can manage to use the string trimmer along the house and sidewalks without getting all green.
It really shines on the creek banks and cutting the fencerow and tree branches under control that want to scrape the tractor and me. The adjustable angle of the head is very useful. The creek banks have been difficult to deal with ever since we built here in '89. Regardless of how carefully I start out with a string trimmer it always reaches the point where I end up proceeding with reckless abandon and getting so miserably covered with plant bits and juice that I need to hose off my glasses and face afterward. With the scythe, the cut plants simply fall over. My clothing, glasses and face are as clean when the trimming is finished as they were when I started. Since we have poison ivy lurking here and there, that's major for me.
Mine is a 94R and has plenty of power. It will saw through tree branches to about 3/4" without too much effort.
/ Weed Whacker Kwik Loader or Bump Feed Head? #17
My Honda has saw blade. It'll cut through hardwood saplings up to about 2" without even slowing down. The problem is that you can't see what's in the brush. Around here there's lots of rocks that will ruin the blade. I like the idea of that scythe. It kind of takes hidden rocks out of the picture.
/ Weed Whacker Kwik Loader or Bump Feed Head? #18
I stopped at a Stihl dealer today to see what the power scythe looked like. They don't stock it, but said it is the same mechanism as the hedge trimmer, but with a blade about half as long. It looked that way in their pictures, too.
Bruce
/ Weed Whacker Kwik Loader or Bump Feed Head? #19
That's exactly what I wanted to know. Thanks a bunch!
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
