Cub cadet 1040, fuel coming out of carb
   / Cub cadet 1040, fuel coming out of carb #1
cubcadet925
Worcester, MA
Cub Cadet LTX 1040
Hey all,
My first post here. I decided to join since I'm battling what I thought would be an easy repair. I was having some choke issues with my cub cadet 1040 ltx 1040, w/ kholer engine SV590-0220. I removed the carb, cleaned it out, and reattached. When i reconnected everything, and put some gas in the mower, now I'm getting fuel coming out of the hole where the choke plate is at. What could be causing this? I've taken it apart, checked out the float, and can't make a bit of sense out of this.
Any thoughts?
   / Cub cadet 1040, fuel coming out of carb #2
Float valve isn't sealing allowing fuel to overfill the carb. Most likely you will need to replace the valve which may only be available in the repair kit for your engine.
   / Cub cadet 1040, fuel coming out of carb #3
I agree; except that often the float valve is ok, but has a tiny fleck of gunk stuck in the float needle/seat, or something mechanically keeping the float from hinging up to shut off flow. Examine the tip of the needle very closely with a magnifying glass for any cracks or significant ridges, and blow everything out with carb cleaner and then compressed air. Any chance that the float is cracked and "sunk"? Also check for proper function of the fuel shutoff solenoid valve threaded into the center of the bottom of the carb float bowl. You should be able to hear it click when you switch the key off and on. Often they have a faulty ground connection or main wire that can be easily corrected.
:welcome:
- Jay
   / Cub cadet 1040, fuel coming out of carb #4
Hey all,
Any thoughts?
try this: remove carb from engine. disasm and soak overnite in liquid carb cleaner. Using magnifier and small dia stiff brass wire, probe EVERY passageway/orifice in each component, blowing same out with compressed air. Rinse each component in clean fluid and lay out in order to dry.
Rebuild carb using components/direction from correct carb rebuild kit. Do NOT re-use any old needles/seats or gaskets. Above all, work clean.
Remount carb, retest.
2015 Ford F-350 Pickup Truck, VIN # 1FT8W3DT3FEB68945 (A54865)
2015 Ford F-350...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Diesel Generator (A55851)
Diesel Generator...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
