SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,514
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Yes.yes it feels great - lawn is out of control and needs a cut - the repair at John Deere was quoted to put in two new heads, and the price with taxes and shop supplies was $575 USD - I bought a new pushrod and then lots and lots of time learning, cleaning... I did end up with new maintenance items, oil, filters, plugs and also some new parts, compression gauge, feeler gauge.. but those are useful for the future - so all in all as I was able to reuse all the parts and clean everything up, it was just $10 for the new intake pushrod... now I know how to take care of this and how to do a head, and adjust valves - in trying to get my old pushmower going I learned how to clean the carb - so probably that will be next on this machine.
So lessons are -
- run good gas and use stabilizer
- as part of regular maintenance check valves and adjust
- for winter storage either run it out of gas or use stabilizer (probably best just to use stabilizer all the time)
- for winter storage maybe drain the carburetor (real easy on this unit with the solenoid switch removal acting as a drain plug)
- use fresh gas - never let gas sit (drain and reuse in the ole truck, or save it for cleaning parts)
- turn it over more than once a week just to be safe (keep things flowing and avoiding any jammed intake valves)
any more ideas or thoughts on this ?
Thanks again everyone.
Varnish to stick a valve in 60hrs, intake no less, is hugely weird. ... Like gasoline was flooding the valve guide during storage.
...I would put some 2 stroke oil in the gas and run it under load a while before storage.
