50 hour maintenance hydro fluid
/ 50 hour maintenance hydro fluid #1
iis
CT
none yet
My l3200 manual says not to change the hydro fluid at 50 hours. I don't want to rehash the issue but maybe we can take a poll?
At the 50 hour maintenance point what did you do knowing Kubota does not recommend it?
/ 50 hour maintenance hydro fluid #2
Hydraulic fluid will go several hundred hours before you even need to worry about it. I guess I am continually amazed why so many people get confused by the 50 hr service. Filters only.
/ 50 hour maintenance hydro fluid #3
Every other week this question is asked. Why change the fluid if they don't ask you too?
/ 50 hour maintenance hydro fluid #4
When the tractor is built, they have all these parts integrated together into the "system", and things like pumps and gears and everything in the tractor wear-in when used for the first few hours (burs, sharp edges in general, smut from heat treating that didn't get completely cleaned out, dirt, etc). You swap the filter because it's job is to collect and trap all that junk as it's circulated through the plumbing. Once you've achieved break-in, you change the filter so it's not loaded up with the break-in debris. The oil itself hasn't been worn yet, it's just been transporting the crud your filter has taken out.
/ 50 hour maintenance hydro fluid #5
Exactly.
Do you change your automobile transmission fluid at 50hrs (3000 miles)??
/ 50 hour maintenance hydro fluid #6
Just follow the d*mn manual. Clean any strainer, replace filters, but don't waste your money on the hydro fluid at 50 hours. Oil is another matter.
/ 50 hour maintenance hydro fluid #7
My B3200 was HST and I only changed the filters at 50 hours. Changed every 400 hours after that. 1200 hours no issues. Traded for L3901. Just changed filters at 50 hours.
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2005 Ford F-150 Ext. Cab Pickup Truck (A61573)
2005 Ford F-150...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
Caterpillar D9R Tractor Parts and Service Manuals (A63117)
Caterpillar D9R...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
