you can get a "meh" forget key term. one end of the chain has a large O instead of a hook. all you do is drop chain around post, and as you pull up on the chain it tights automatically through the O on the one end. then i tend to have to wrap chain 2 to 3 times. so chain does not slide off of post. there are a couple other chain like devices but have better "grasps" with some small teeth on them that sink into metal posts. so there is no slipping.
I wonder how many that replied didn’t actually click on the link?
Nothing works better than a plain old chain for pulling posts, but the reason these contraptions exists are to make pulling posts much faster for only one person. If you have dozens or hundreds of posts to pull by yourself, you’re going to get tired of climbing on and off the tractor real fast. To answer the original question; I’ve never used one, and it seems like and intriguing way to pull trees/shrubs. Not cheap for a bit of steel, though.
That one clamps to the bucket. Northern Tool sells one that slips over a set of pallet forks. I think I'd prefer the Northern Tool design as the clamp on kind would seem to put a lot of stress on the bucket.
But the Northern Tool one doesn't get very good reviews on their site. Brush Grubber Post/Tree Puller Model# BG-10 | Weed Control Brush Removal| Northern Tool + Equipment
This looks like something that would be easy to build for someone with a welder and a cutting torch and some scrap metal.
Well said. I have 1,600 feet of wooden fencing to pull up 4x4 posts. And using a cab tractor - my hope is to chain saw cut the fencing boards between the post, then get back in my cab for a few hours
