CTWright
- Joined
- Nov 10, 2014
- Messages
- 94
- Location
- Santa Fe, NM
- Tractor
- 1959 MF65 Diesel and 1959 Ford 641 gas
Reinstalling the front end loader on my 59 MF-65 diesel. When hooking up and bleeding the lift arm cylinders I had some problems. Im using the tractor internal hydraulics with I believe is the factory diverter mounter under the seat. I have the 3 point section lever in the center position and the diverter to the FEL pulled towards the rear of the tractor. The cylinders lift fine when I pull back on the external spool valve. (I have a three valve set up mounted on the right post). When I go to retract, the cylinders keep lifting. The only way to retract is to switch the diverter valve to the forward position and pull the lever the same way as lifting.
So, what am I missing here. It appears the fluid is not returning back. Is my control spool valve mounted on the post malfunctioning? I did switch it with the bucket valve with no change. Is my diverter valve malfuntioning? Does my quadrant lever position affect the operation?
