Killing Sumac and locust
/ Killing Sumac and locust #1
Hammer Head
Lock Haven, PA
Kubota L3800 HST, Scag Tiger Cat
I am planning to purchase a tank and sprayer. I will be making a platform to connect it to my loader bucket with quick connect for the power.
My big question is what is the best to kill sumac and locust? I have always user Round Up, my friend is telling me to use Cross bow. Might be good to know what type of pump and tip will cover the most distance also?
The area I want to kill is a steep hillside. I have cut it every other year and it is tough to get around on. I might be getting a little older also, hope this fall is the last!
I will spray it in the spring when everything is starting to shoot up.
/ Killing Sumac and locust #2
You have a number of options.
Locust will be easy to kill if you do it at the correct time. A good rule of thumb is after July 1 on locust. You likely will do individual plant treatment so mixing Crossbow at 1 1/2 to 2 % in water will do fine. (1%=1.3 oz per gallon of water) CB will kill sumac at that same time frame. Just make sure you get coverage on the plants you want to kill
/ Killing Sumac and locust #3
I use a "fence line" spray from my local ag store and it works great. RoundUp won't work as well and it'll kill the grass too. The fence line spray is basically 2-4d with some other chemical mixed in.
/ Killing Sumac and locust #5
Sumac is easy to burn the leaves off and not harm the tree at all. You have a tractor, yes? Get a section of nylon webbing, like 1" double walled, and make a loop out of it about 18" long (4' of webbing will work nicely) using this water knot: Water Knot | How to tie the Water Knot | Climbing Knots
Then you just loop the loop over on itself and pull the end through to make a strap hitch: Girth Hitch | How to tie the Girth Hitch | Climbing Knots
And then pull on that with your chain. Sometimes when they're still growing, you'll peel the bark off, but you just reposition the hitch and pull again and the whole thing will come out of the ground.
Roots on sumac are huge and tend to be very resilient. You might try "hack and squirt" during the growing season (any time now would be fine) with regular 2,4-D, but I've found yanking them is really the only way to make a dent in the population. You can cut them, and they'll stump sprout. Spray too hard and they just drop the leaves. But rip the SOB's out of the ground and they don't handle that too well. :)
I am dealing with a large steep bank, just trying to cut them is a task. I think if I try to pull them out 100+4'-8' trees it could loosen the soil and create an erosion problem.
At this point I think spraying them is the only option.
The local power lines are filled with sumac and the commercial spraying does a good job of killing them for several years.
/ Killing Sumac and locust #8
Our power company won't touch sumac because it doesn't grow tall enough to interfere with the lines.
/ Killing Sumac and locust #9
Crossbow should do it. Or I use the generic brand of this, called Crossroads from Rural King. It will knock out all brush and trees, but leave the grass and grassy weeds to retain the hillside. As with any herbicide, be sure to mix at the recommended strength. Mixing it too strong or too weak results in partial kills and more problems.
/ Killing Sumac and locust #11
I have a problem with weeds (that my goats won't eat) Can anyone tell me
if I can spray CB or RU on the weeds, and leave the goats on the pasture.
Thanks all for the good advise.
50' distance looks good for the sprayer and CB looks like the best option. I will be ready to do battle in the spring.
/ Killing Sumac and locust #13
See Grazing and haying restrictions for grass forage and pasture herbicides ? Penn State Agronomy Guide ? Penn State Extension.
You would be OK with Crossbow. The PSU report says to wait seven days for glyphosate, but I believe that the seven-day delay is to give the herbicide time to translocate within the treated plants.
BTW, welcome to TBN from another Iredell County member.
Steve
/ Killing Sumac and locust #14
I have an invasive bush called Asian honeysuckle or bush honeysuckle and If I don't pull the root ball out I cut it down and pour on Tordon and it kills it. I get it in a quart bottle with a reclosable multiholed top. Spraying it with a brush killer knocks the leaves back but doesn't kill it.
/ Killing Sumac and locust #15
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
