First Time Brush Hog User with Questions
/ First Time Brush Hog User with Questions #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I am using a brush hog (John Deere 616) for the first time and have a few questions.
1. Should the front (leading edge) of the hog touch the ground or be some distance above the ground?
2. How will I know the shear bolt has sheared? Sound? Hog stops Cutting?...?
3. There are no "feet" on the hog. Should there be?
/ First Time Brush Hog User with Questions #2
1. No, see this: https://www.youtube.com/watch?v=T-Thfr3fChg
2. Hog stops cutting even though shaft is turning; easy to see missing shear bolt.
3. I don't understand the question.
/ First Time Brush Hog User with Questions #3
1. No, couple of inches off the ground, tailwheel supporting rear of hog, front of hog slightly lower than rear.
2. Hog stops cutting but PTO shaft keeps turning.
3. I don't believe that cutter came with shoes. You can weld on some flat stock if you like. Bend it in a vise and weld it on the leading edge look at pic for example.
/ First Time Brush Hog User with Questions #4
I see TripleR types more faster! What he said!
/ First Time Brush Hog User with Questions #5
To add just a bit more detail;
1) the height of the front of the hog (plus the tailwheel) will set the cutting length. If you want a really short cut, set the front of the hog right at ground level. Just beware that this will wear the front edges/skid shoes of the hog faster when it inevitably does drag.
2) you will quickly find that the turning hog blades make a very distinctive sound. So when there is a BANG and then that sound stops, the shear pin is most likely knackered.
3) some manufacturers/models of hog are supplied with replaceable bolt-on skids on the sides, some not. Mine (BushHog 296) are replaceable but I will most likely just weld some new metal on top once they get near to wearing through. Hasn't happened yet in 8 years of use on about 15 acres plus about a mile of gravel road.
- Jay
/ First Time Brush Hog User with Questions #6
I am using a brush hog for the first time and have a few questions.
If this a storage question, store your Rotary Cutter on a pallet, with the rear wheel on the ground and wood blocks/bricks/concrete blocks (mine are 6" X 6" pine blocks ) supporting the front of the mower. This allows air to circulate and dry surfaces underneath.
Cover with a cotton canvas tarpaulin. If you buy 18 ounce or heavier weight, you will not have to tie tarp down.
<<Plastic tarpaulin will allow water to a condense on your cutter, leading to rust.>>
/ First Time Brush Hog User with Questions #7
Couple of years back, I bought a 5' CountryLine rotary cutter from TSP. Even with the front edge almost touching the ground, I couldn't cut as short as I wanted (yeah, I know it's not a finish mower :c). In an case, I measured from the blade to the bottom of the skirt and it was something like 5 3/4" IIRC. I promptly cut off the bottom of the skirt and welding 3/4 square tubing to reinforce the bottom edge (it originally had a lip, 90 degree bend to reinforce it). Works much better now and the skirt still provides the needed protection from flying objects.
Old Bush Hog Squealer didn't have that problem, but I guess liability is pushing some makers to add taller sides to their mowers.
/ First Time Brush Hog User with Questions #8
It doesn't really hurt anything for the front dragging except it makes ugly ruts in the field. It is pretty obvious when a shear pin shears. There was probably a loud bang then the blades no longer spin. The pto shaft will continue spinning because the pin is at the gear box.
/ First Time Brush Hog User with Questions #9
Which is why there's typically some method, such as a Cir-Clip or spring clip in a groove at the end of the gearbox shaft) to make sure the gear box end of the PTO shaft universal joint doesn't come completely off the shaft - - lest the PTO shaft wildly flail hither and yon whilst doing its best to smite you down.
