3PT Back hoe
/ 3PT Back hoe #1
jjlite
U.P. MICHIGAN
mahindra 4035
Looking at a 3pt 765H It appears to be in very good shape. The seller says he has only used a couple of times. (I know the seller and is a straight up guy) Says if he cant get 3K hes keeping it. What do you all think?
/ 3PT Back hoe #2
There are about to be several people replying that 3pt how's are a bad idea & can break the toplink mount or transmission. Some will argue with that, but personally if I end up with a hoe, I'm going to make sure it has a subframe for a stronger mount that won't beat up my tractor.
/ 3PT Back hoe #3
yup.
I broke a lift arm once, and a top link once. When the top link broke, the face down ride into the hole I was digging was a thrill.
/ 3PT Back hoe #4
I've used a 3 pt for going on 4 years no issues at all. But as Fallon said, prepare for the onslaught!:laughing:
/ 3PT Back hoe #5
3K is a good price for a barely used BH. I paid $3400 for a used Woods BH750-3 but it came with a sub frame which I adapted to fit my tractor. It attaches at 5 points, 4 on the sub frame plus a top link.
If you get it I agree with the others about having a sub frame. There's many threads here on building your own frame. If minedidn't come with a frame I'd have built one for it.
/ 3PT Back hoe #6
Mine worked fine for 15 years, and then................ snap, crackle, ouch.
The subframe makes the whole unit stiffer and much easier/nicer to use.
/ 3PT Back hoe #7
If I make it another 15 years I sure hope I have a new tractor by then. The sub frame for my FEL goes from the front frame to the rear axle. Maybe that is what is saving me. If you could have witnessed the incredible abuse my 3 pt hitch has tolerated for 30 plus years you might understand why that 5' hoe doesn't worry me.
/ 3PT Back hoe
I Like the idea of a sub frame and it may be in my future. Im headed out tomorrow to fit it and give it a test spin.:)
HONDA generator (A64553)
HONDA generator...
121A (A63745)
121A (A63745)
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2019 Ford F-350...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2201SFL (A64553)
2201SFL (A64553)
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
