1725 starting issues
   / 1725 starting issues #1
Mtriangle
Pearce AZ
NH 1725
The battery is good, and I have checked the neutral safety relay for continuity, and the fuses. I checked the ignition switch for continuity as well--all positions are good. I do get a glow plug and red light, but no starting--it acts as if the safety relay is active.
What is the best next step? Pull the alternator and have it tested? Check the solenoid on the starter? We ranch and I would like to avoid a service call or trailer in.
Many thanks.
Mtriangle
   / 1725 starting issues #2
The battery is good, and I have checked the neutral safety relay for continuity, and the fuses. I checked the ignition switch for continuity as well--all positions are good. I do get a glow plug and red light, but no starting--it acts as if the safety relay is active. What is the best next step? Pull the alternator and have it tested? Check the solenoid on the starter? We ranch and I would like to avoid a service call or trailer in. Many thanks. Mtriangle
Does it turn over or do you just hear the clicking of the starter.
It does not turn over. There is usually one click and then nothing.
In thinking it over, I guess I should check the voltage between the battery and solenoid when I turn it to start.
   / 1725 starting issues #4
It does not turn over. There is usually one click and then nothing. In thinking it over, I guess I should check the voltage between the battery and solenoid when I turn it to start.
If the battery is good, check the connections to the starter. My 1910 just started to act up (clicking) cleaned the connection up and no problems. It had lots of corrosion. If that's not it I would check ground to frame from battery. Hope this helps.
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
Informational Lot - Financing (A56436)
Informational Lot...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
2016 Ford F-350 (A55973)
2016 Ford F-350...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
